S32DS compilation error
4,000件の閲覧回数
leeli
S32DS compilation error program "gcc" not found in PATH; but it can be compiled and passed, what is the reason for this?
タグ(1)
3,291件の閲覧回数
yinzc
Hi,i have the same problem,have you solved the problem now?
3,949件の閲覧回数
nxf57422
did you run export PATH=<path for gcc> ? Can you add build logs for additional info, thanks
Best,
Marco Cesarano
