where I can get FFT demo code or library for MC56F82xxx?
1,483 次查看
terrybogard
from datasheet i noticed that mc56f82xxx had the  Bit reverse address function which is used for FFT, but where i can get the FFT demo code including the Bit reverse address function. i need FFT to realize input power quality evaluation.
1,476 次查看
xiangjun_rong
Hi, Terry,
The PE(Processor Expert) in CodeWarrior for MCU tools has the signal processing bean, with which you can develop FFT.
Hope it can help you
XiangJun Rong
1,477 次查看
xiangjun_rong
Hi, Terry,
XiangJun Rong
1,462 次查看
terrybogard
thanks for xiangjun’s answer, could you pls give the guidance about how to use this bean?
