Target processor setting
2,580 次查看
Chanh
I am using CodeWarrior for QorIQ LS Series with FRWY-LS1046A board, I follow the user manual to create bare metal project. When I go the the setting page, the target processor is cortex-m3 and cannot be changed. May I know any problem with that option if I run the binary file on the board? And how to change the processor to cortex-a72?
Thanks.
2,575 次查看
yipingwang
No need to do modification, please use the default setting, this option will not be used in the compilation.
2,564 次查看
Chanh
Hi Yiping,
Got it. Thanks.
2,576 次查看
yipingwang
