Target processor setting
Chanh
I am using CodeWarrior for QorIQ LS Series with FRWY-LS1046A board, I follow the user manual to create bare metal project. When I go the the setting page, the target processor is cortex-m3 and cannot be changed. May I know any problem with that option if I run the binary file on the board? And how to change the processor to cortex-a72?
Thanks.
yipingwang
No need to do modification, please use the default setting, this option will not be used in the compilation.
Chanh
Hi Yiping,
Got it. Thanks.
yipingwang
