QCVS install error
QCVS install error
12,628 次查看
mohsenhaghighat
when I install QCVS in eclipse. this error has been occurred.
I use QCVS for qoriq power version 4.5.0.00001 . the eclipse version is "Eclipse IDE for C/C++ Developers 4.4.2".
Any body can help me.
An error occurred while collecting items to be installed
session context was:(profile=epp.package.cpp, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=null --> [R]com.freescale.qcvs.feature_root 4.5.0.0001-20160210, action=).
The required Touchpoint: com.freescale.updater.touchpoint 1.0.0 touchpoint for the collect action is not included in the installation manager configuration.
thanks.
10,289 次查看
addiyi
The correct update site for installing QCVS + FSL Updater is http://freescale.com/lgfiles/updates/Eclipse/QCVS for only ARM support or http://freescale.com/lgfiles/updates/Eclipse/QCVS_PA​ for QCVS 4.5 release including ARM + PA support.
Please refer to QCVS Installation Guide, chapter 3.2.
Adrian
8 回复数
10,289 次查看
florentinbourge
I had a similar problem with the same error message ! Juno 4.2 + QCVS for qoriq power version 4.5.0.00001
So I follow advices fromaddiyi‌ which are good, but I omited to install the "Eclipse Freescale Solutions Category" first. That was my second problem.
So,
  1. Add a new repository into eclipse : Help -> Install New Software :
  2. Firstly install : Eclipse Freescale Solutions Category, only ! -> Restart eclipse.
  3. Secondly install the : QorIQ Configuration and Validation Suite 4.5. -> Restart eclipse
Everything work fine .
10,289 次查看
addiyi
Did you install first "Eclipse Freescale Solutions Category"?
Adrian
10,289 次查看
mohsenhaghighat
I use eclipse 4.2 Juno.
I find "Eclipse Freescale Solutions Category" at Processor Expert Software, Microcontroller Driver S|NXP  and install it.
and then I try to install QCVS but it error "No action found for: com.freescale.updater.customActions.freescaleprocesscheck."
I cant use from this link : http://freescale.com/lgfiles/updates/Eclipse/QCVS_PA .
I think that  "Eclipse Freescale Solutions Category" has mistake. where can I download it?
10,290 次查看
addiyi
Adrian
9,566 次查看
Kernelhacker
How do we access this locations?
getting "Page not found"
9,517 次查看
jorge_plascencia
This can only be access using the CodeWarrio SW under Help > Install new SW
9,515 次查看
Kernelhacker
OK, thanks.
But I was trying to integrate with eclipse. Isn't that possible by any means?
9,510 次查看
jorge_plascencia
  1. Inside of the CodeWarrior Tools click on Help > Install New Software
  2. You will see the updates that are abaiable for your software
  3. Can you send a Screen capture of what you see please.
