LS1046a OCRAM ECC
LS1046a OCRAM ECC
sanspepin
  1. Is there a way to inject SBE or MBE ecc error for the ls1046a OCRAM?
  2. Is the MBEE_MSK from the RSTRQMR register is related to the OCRAM?
    1. If  the MBEE_MSK is 0, the RESET_REQUEST_B will trigger on MBE error?
yipingwang
In response to the above queries:
NXP:SBE or MBE ecc error can be cleared but not injected for the LS1046A OCRAM. Refer note under section "7.2 On-Chip RAM memory controller (OCRAM)" of LS1046ARM_Rev3.
NXP:Yes, MBEE_MSK from the RSTQMR is related to any of the SRAMs inside the chip including OCRAM.
NXP: Yes, It is fine if it remains set. If MBEE_MSK is =0 then while the system is running and encounters an MBEE event then the RESET_REQ_B signal will be asserted, which if it is connected to HRESET will cause a reboot.
yipingwang
%3CLINGO-SUB%20id%3D%22lingo-sub-1942781%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS1046a%20OCRAM%20ECC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1942781%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3COL%3E%3CLI%3EIs%20there%20a%20way%20to%20inject%20SBE%20or%20MBE%20ecc%20error%20for%20the%20ls1046a%20OCRAM%3F%3C%2FLI%3E%3CLI%3EIs%20the%20MBEE_MSK%20from%20the%20RSTRQMR%20register%20is%20related%20to%20the%20OCRAM%3F%3COL%3E%3CLI%3EIf%26nbsp%3B%20the%26nbsp%3BMBEE_MSK%20is%200%2C%20the%20RESET_REQUEST_B%20will%20trigger%20on%20MBE%20error%3F%3C%2FLI%3E%3C%2FOL%3E%3C%2FLI%3E%3C%2FOL%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1959603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS1046a%20OCRAM%20ECC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1959603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIn%20response%20to%20the%20above%20queries%3A%3C%2FP%3E%0A%3CP%3EIs%20there%20a%20way%20to%20inject%20SBE%20or%20MBE%20ecc%20error%20for%20the%20ls1046a%20OCRAM%3F%3CBR%20%2F%3ENXP%3ASBE%20or%20MBE%20ecc%20error%20can%20be%20cleared%20but%20not%20injected%20for%20the%20LS1046A%20OCRAM.%20Refer%20note%20under%20section%20%227.2%20On-Chip%20RAM%20memory%20controller%20(OCRAM)%22%20of%20LS1046ARM_Rev3.%3CBR%20%2F%3E%3CBR%20%2F%3EIs%20the%20MBEE_MSK%20from%20the%20RSTRQMR%20register%20is%20related%20to%20the%20OCRAM%3F%3CBR%20%2F%3ENXP%3AYes%2C%20MBEE_MSK%20from%20the%20RSTQMR%20is%20related%20to%20any%20of%20the%20SRAMs%20inside%20the%20chip%20including%20OCRAM.%3C%2FP%3E%0A%3CP%3EIf%20the%20MBEE_MSK%20is%200%2C%20the%20RESET_REQUEST_B%20will%20trigger%20on%20MBE%20error%3F%3CBR%20%2F%3ENXP%3A%20Yes%2C%20It%20is%20fine%20if%20it%20remains%20set.%20If%20MBEE_MSK%20is%20%3D0%20then%20while%20the%20system%20is%20running%20and%20encounters%20an%20MBEE%20event%20then%20the%20RESET_REQ_B%20signal%20will%20be%20asserted%2C%20which%20if%20it%20is%20connected%20to%20HRESET%20will%20cause%20a%20reboot.%3C%2FP%3E%3C%2FLINGO-BODY%3E
