Code Warrior Targeted compilation
2,084 次查看
Geek19
I have a test code that compiles and links with no problem when I target RAM using the evaluation CW 2.7 on Windows 7 and EVAL board MPC5554. As I choose the Flash as my target the compile and link process results in several Compiler errors, warnings as well as Linker errors. Could you please explain this and show me how to resolve this matter.
Thanks;
标记 (1)
1,473 次查看
Geek19
I got the answer for this question! And the answer is the P&G debugger that accompanies the Evaluation board was not loading the right *.elf  for the compiled code even though it was being launched by CW software! Basically the CW does not communicate the name of the CURRENT *.elf with the P&G debugger. The user shall pay attention and set this as needed.
Thanks;
1,474 次查看
Geek19
Thanks;
