using multiple ADC Bean on a MC9S08AW32
1,784 次查看
vlm
I'm using Processor Expert in an application based on a MC9S08AW32.
I want to use either the ADC with 6 inputs or the ADC with 2 other inputs (differents  from the 6 first), depending on a code received from the serial port.
With Processor Expert I select the ADC Bean and configure it with the 6 first channels.
Processor Expert refuse the declaration of a second ADC Bean.
Is there a way to solve this problem ?
Vincent
J2MEJediMaster added MCU to header
Message Edited by J2MEJediMaster on 2007-04-25 10:33 AM
标记 (1)
873 次查看
vlm
I'finally found by myself : switch the item "sharing" to "enabled" for each of the ADC bean.
Vincent
874 次查看
vlm
Vincent
