Using the Visualization Tool to generate an interrupt
4,238 次查看
whitea
Is there any way to use the Visualization Tool, particularily the switches, to generate an interrupt? I am currently trying to generate the IRQ_L interrupt using a switch. I understand the IRQ_L is the 2nd LSB of Port E. While I can modify this value using the switch, no interrupt occurs as far as I can tell. Any help would be greatly appreciated as the documentation on the Visualization Tool does not address interrupts. Thank you.
Andy
标记 (1)
3,015 次查看
CrasyCat
Specialist III
Hello
Today you cannot generate an interrupt from the visualization tool.
CrasyCat
4 回复数
3,015 次查看
whitea
Thank you so much for the response. Is there a way to generate an interrupt using any of the components other than the IT_Keyboard? I'm still using an old version (4.6) as a teaching aid and it has the old components that version 5.0 does not.
3,015 次查看
whitea
I also meant to mention that I'm using the Simulator and Debugger and not actual hardware. Is there a way in the Simulator to generate an interrupt? (other than the IT_Keyboard component)
3,015 次查看
CrasyCat
Specialist III
Hello
Only component I know allowing you to stimulate (Raise) an interrupt is the stimulation component.
Bad news is that component is available in professional edition only and for HC12, HCS12 AND HCS12X MCUs only.
CrasyCat
3,016 次查看
CrasyCat
Specialist III
Hello
CrasyCat
