Stop Pop Up at startup
2,031 次查看
ronaldpatton
How do I prevent this pop up when starting Code Warrior 10.6?  The evaluation version was initially installed.  It has since auto down graded to the "community version".
Ron
1,898 次查看
BlackNight
Hi Ron,
Simply rename the file <install>\MCU\license.dat to a different name so it is not found.
I hope this helps,
Erich
1,899 次查看
BlackNight
Hi Ron,
I hope this helps,
Erich
1,898 次查看
ronaldpatton
Yes, that did the trick,  thanks !
