Immediate addressing HC12
4,519 次查看
Pitrunner
Hello everybody,
I 've flw problem with CW. I want to load two ASCII signs in accu D. The code looks like LDD #'AA'. But I got an error message illegal addressing mode. If I load only one ASCII sign like LDD #'A', all is perfect. Has somebody an idea? Thank you for the help.
标记 (1)
3,035 次查看
CompilerGuru
With a
LDD #('a' << 8) + 'a'
You should get the same code (should because I did not try it out).
I dont think multi byte character constants are supported in the CW HC12 assembler.
4 回复数
3,035 次查看
pittbull
Try this:
// Store 'AB' into D
LDAA #'A'
LDAB #'B'
3,035 次查看
Pitrunner
Thank you for the answer.
This solution I know.
LDAA#'A'
LDAB#'A'
But we have here an old HP assembler for our HC11 controller and with that assembler the
LDD #'AA' instruction works.
3,036 次查看
CompilerGuru
With a
3,035 次查看
Pitrunner
Daniel,
thank you for the hint that multi byte character aren't supported with CW.
So I will try your solution.
