CW5.1, Simulator
CW5.1, Simulator
Truk
I have a free version of CW5.1 (developpement in assembler).
I would like to working into the visualisation tool. Are there samples how to do this?
regards,
Truk
CrasyCat
Specialist III
Hello
if you want to get more than 3 instruments in your visualization tool window, you need to upgrade to a standard edition.
Standard Edition is not free and you will have to pay for it.
CrasyCat
CrasyCat
Specialist III
Hello
Only description I am aware of is in the {install}\Help\PDF\Debugger_HC08.pdf.
Chapter "Book I - Debugger Engine", section "Debugger Components"  -> "Visualization Utilities" -> "VisualizationTool Components" describes he available instruments and properties for each of them.
I am not aware of any other document.
CrasyCat
Truk
Hi CrasyCat,
in my free version the simulator is only in demo mode and has only the possibility of 3 VisualizationTool Components.
Is it possible to upgrade the free version to a nonlimitated VisualizationTool?
regards,
Truk
CrasyCat
Specialist III
Hello
CrasyCat
