Error can not open ansiis.lib file
1,686 次查看
Sunil_Reddy
Hi all
I am using Code Warrior on Windows 7 platform. When I do Build Project (Build All) I am getting an error message as below
"can not open file "C:\.......\ansiis.lib"
ELF: can not open file "C:\.......\ansiis.lib"
Had anyone encountered similar kind of problem? What could be the reason of this problem? How to add/delete the ansiis.lib files?
Thank you very much
Sunil
标记 (1)
1,167 次查看
kef
Specialist I
Are you porting S08 project to S12?
CW for S12 doesn't have ansiis.lib, but it has ansisi.lib.
CW for S08 doesn't have ansisi.lib, but it has ansiis.lib.
1,168 次查看
kef
Specialist I
