Can I use CW Eclipse IDE to programm a MC68HC908 MCU
fwolf
Is it possible to use the CodeWarrior Eclipse IDE to program a MC68HC908 MCU?
I know, that the classic IDE has support, but it's not possible to install this on a Win7 64 bit machine.
Thanks in advance
Frank
ZhangJennie
Frank.
unfortunately CW eclipse version doesn't support HC08 programming.
One if the importance aspect is that HC08 device uses MON08 interface but CW eclipse doesn't support.
I suggest you install CW6.3 on 64bit win7 with this workaround
Install CodeWarrior 6.3 Windows 7 & 10 x64 directly (Classic version)
Hope this helps!
Jennie Zhang
fwolf
Hi Jennie,
Thank you.
Meanwhile I have installed the CW 6.3 in a XP virtual machine, works too.
ZhangJennie
Frank.
Hope this helps!
Jennie Zhang
