Is it possible to use the CodeWarrior Eclipse IDE to program a MC68HC908 MCU?
I know, that the classic IDE has support, but it's not possible to install this on a Win7 64 bit machine.
Thanks in advance
Frank
解決済! 解決策の投稿を見る。
Frank.
unfortunately CW eclipse version doesn't support HC08 programming.
One if the importance aspect is that HC08 device uses MON08 interface but CW eclipse doesn't support.
I suggest you install CW6.3 on 64bit win7 with this workaround
Install CodeWarrior 6.3 Windows 7 & 10 x64 directly (Classic version)
Hope this helps!
Jennie Zhang
Hi Jennie,
Thank you.
Meanwhile I have installed the CW 6.3 in a XP virtual machine, works too.
Frank.
Hope this helps!
Jennie Zhang
