security set on mc9s08dz128
1,447 次查看
martinlockner
While experimenting with the freescale bootloader I have apparently secured the device. I am unable to download new firmware using the flash programmer. I am wondering if there is a setting in the flash programmer that will override the security lock?
1,324 次查看
ZhangJennie
Hi Martin,
if your HCS08 device is secured, the only method to unsecure it is mass erase.
please perform mass erase before launch debugger.
this answer is for you. if it helps, please click on "correct answer " button. thanks!
Zhang Jun
1,325 次查看
ZhangJennie
Hi Martin,
Zhang Jun
