explicit-dependencies  Stop.
1,589 次查看
younsooahn
I have good working a project(S12zvm referance sourcode)
But this project copy to other new setup pc
Then i have blow problem
I did compile but i did see below Error Message
"mingw32-make: *** No rule to make target `../src/S12ZVM_system/startup_CW/S12zvm.prm', needed by `explicit-dependencies'.  Stop.
How can solve this problem?
1,378 次查看
ZhangJennie
can you please check if parameter file path setting is correct?
after that, go to IDE menu "project" , "clean". then rebuild the project.
can this help you?
Jennie Zhang
