Print settings
Print settings
3,104 次查看
pascalschröer
Hi at all,
Can anyone tell me, how to set up some print settings in CW10.6?? I would like
to set up the distance between the code and the page borders... The "normal"
printer settings don't have options like that.
Thanks!
Pascal
标记 (3)
2,999 次查看
pascalschröer
Now, I have solved the problem! There isn't an option to set up the side clearance, so you have to
scale down the printed window!
Pascal
2,999 次查看
catalindemergia
After File->Print, select your printer and then hit the Preferences button,
you will find all the settings there.
regards,
Catalin
2,999 次查看
pascalschröer
Hey,
Ok I have seen this settings but I can't set up the side clearance... Do you know
a solution for this problem?
Thanks!
Pascal
3,000 次查看
pascalschröer
Pascal
