Port pins remains latch at high position when debugger is stopped in Codewarrior
1,243件の閲覧回数
hemantsindkar
I am using KEA128 and OpenSDA in my project. I am generating PWM signal on port pin. In debug mode if I stop in debug mode, port pin which is generating PWM signal remains in high state. How to fix this.
1,126件の閲覧回数
Hello Hemant,
When it run , do not stop, does the PWM can work well ?
You stop the debug, the project stopped, so there is no problem it remains high or low .
Alice
