INTERNAL ERROR: at line 7048: File not found: CODE\smm_pROM_xRAM.cmd (file: Drivers\56800\DSP56800.drv)
855 次查看
samzhang
It seems can't find the file with the special revision of Codewarrior V8.3 when click 'make' button. Is this the revision issue or my computer?
785 次查看
xiangjun_rong
Hi, Sam,
It seems that you do not select the correct the configuration, pls see the screenshot:
If it does not fix your problem ,pls show the error message screenshot so that we know the detailed error inf.
Xiangjun Rong
