How can I add an assembly listing file on the Eclipse CW10.6?
2,279件の閲覧回数
mardalianis
Or should I keep on using CW6.3?
2,116件の閲覧回数
ZhangJennie
Hi Chris,
in addition, we can also set "generate listing file" in compiler settings.
setting "Configure listing file" can define what shows in lst file.
if you use assembly, you can also set "generate listing file" in assembler setting.
does this answer your question?
Zhang Jun
3 返答(返信)
2,117件の閲覧回数
ZhangJennie
Hi Chris,
Zhang Jun
2,116件の閲覧回数
mardalianis
Thank you both for your help. I'm a bit careless lately...:smileyplain:
2,116件の閲覧回数
BlackNight
Hi Chris,
I'm not sure what you mean.
But if you want to careate a disassembly listing, simply use the context menu on the source/Editor view:
I hope this helps,
Erich
