HC12 compiler Warning
shiju_varghese
I am using the compiler HC12 (5.0.14) for the development of MC9S12DG128 controller. Now it shows some warning like limited the code. How can I resolve this problem? Please help me.
shiju_varghese
OK. Thanks for your quick response.
How can i get the licence?
ErichStyger
Specialist I
If you click on 'extendeded information', you get the information about the licensing status.
And there is Licensing and Registration | NXP
shiju_varghese
I have uploaded the installed plugin details and screen shot of about page.
Bin\Plugins\com
CPPCodeCompletion.dll 5.9.0 Build 5294 5.9.0.5294 5.9.0.5294 8/5/2010, 5:45 PM 808K
DebugDatabase.dll 5.9.0 Build 5294 5.9.0.5294 5.9.0.5294 8/5/2010, 5:53 PM 324K
DebugRegisterMgr.dll 5.9.0 Build 5294 5.9.0.5294 5.9.0.5294 8/5/2010, 5:53 PM 116K
HC12Wizard.dll 5.2.10221 5.2.0.10221 5.2.0.10221 8/10/2010, 7:10 PM 960K
MWActivate.dll 5.9.0.5294 5.9.0.5294 5.9.0.5294 8/5/2010, 5:46 PM 572K
PackAndGo.dll 1,0,0,10221 1.0.0.10221 1.0.0.10221 8/10/2010, 7:11 PM 344K
pe_init.exe No Version Info 0.0.0.0 0.0.0.0 3/17/2009, 10:16 PM 92K
PE_options.dll 1, 0, 0, 13 1.0.0.13 1.0.0.13 8/8/2005, 4:03 PM 32K
PE_Plugin.dll 4.46.1.5287 4.46.1.5287 4.46.1.5287 11/26/2015, 5:58 PM 7.50M
PE_prelink.dll 1, 0, 0, 4 1.0.0.4 1.0.0.4 8/8/2005, 4:04 PM 95K
TipOfTheDay.dll 1,0,0,10221 1.0.0.10221 1.0.0.10221 8/10/2010, 7:11 PM 64K
Bin\Plugins
Bin\Plugins\compiler
hw_hc12_assembler.dll 5.0.14.15249 5.0.14.15249 5.0.14.15249 9/7/2015, 2:53 PM 87K
hw_hc12_compiler.dll 5.0.14.15249 5.0.14.15249 5.0.14.15249 9/7/2015, 2:53 PM 87K
hw_hc12_importer.dll 5.0.14.15249 5.0.14.15249 5.0.14.15249 9/7/2015, 2:53 PM 87K
hw_xgate_assembler.dll 5.0.14.15249 5.0.14.15249 5.0.14.15249 9/7/2015, 2:53 PM 87K
hw_xgate_compiler.dll 5.0.14.15249 5.0.14.15249 5.0.14.15249 9/7/2015, 2:53 PM 87K
hw_xgate_importer.dll 5.0.14.15249 5.0.14.15249 5.0.14.15249 9/7/2015, 2:53 PM 87K
OsekCompiler.dll 2, 1, 2, 0 2.1.2.0 2.1.2.0 9/12/2006, 4:30 PM 75K
PCLintCompiler.dll 1.5 1.5.0.5 1.5.0.5 9/4/2003, 7:28 PM 80K
Bin\Plugins\Editor
HC12_Coloring No Version Info 0.0.0.0 0.0.0.0 3/4/2015, 2:49 PM 46K
MWE_Common_Coloring No Version Info 0.0.0.0 0.0.0.0 3/4/2015, 2:49 PM 29K
XGATE_Coloring No Version Info 0.0.0.0 0.0.0.0 3/4/2015, 2:49 PM 35K
Bin\Plugins\linker
BatchRunnerPostLinker.dll 2.0.0 Build 0006 2.0.0.6 2.0.0.6 7/9/2004, 4:31 PM 40K
BatchRunnerPreLinker.dll 1.0.0 build 0002 1.0.0.2 1.0.0.2 7/9/2004, 4:31 PM 42K
ExternalBuildLinker.dll 5.9.0.5294 5.9.0.5294 5.9.0.5294 8/5/2010, 5:58 PM 80K
hw_hc12_libmaker.dll 5.0.14.15249 5.0.14.15249 5.0.14.15249 9/7/2015, 2:53 PM 92K
hw_hc12_linker.dll 5.0.14.15249 5.0.14.15249 5.0.14.15249 9/7/2015, 2:53 PM 92K
hw_xgate_libmaker.dll 5.0.14.15249 5.0.14.15249 5.0.14.15249 9/7/2015, 2:53 PM 92K
hw_xgate_linker.dll 5.0.14.15249 5.0.14.15249 5.0.14.15249 9/7/2015, 2:53 PM 92K
PCLintLinker.dll 1.5 1.5.0.5 1.5.0.5 9/4/2003, 7:28 PM 84K
Bin\Plugins\preference_panel
hw_hc12_assembler_panel.dll 5.0.14.15249 5.0.14.15249 5.0.14.15249 9/7/2015, 2:53 PM 89K
hw_hc12_burner_panel.dll 5.0.14.15249 5.0.14.15249 5.0.14.15249 9/7/2015, 2:53 PM 89K
hw_hc12_compiler_panel.dll 5.0.14.15249 5.0.14.15249 5.0.14.15249 9/7/2015, 2:53 PM 89K
hw_hc12_importer_panel.dll 5.0.14.15249 5.0.14.15249 5.0.14.15249 9/7/2015, 2:53 PM 89K
hw_hc12_libmaker_panel.dll 5.0.14.15249 5.0.14.15249 5.0.14.15249 9/7/2015, 2:53 PM 89K
hw_hc12_linker_panel.dll 5.0.14.15249 5.0.14.15249 5.0.14.15249 9/7/2015, 2:53 PM 89K
hw_xgate_assembler_panel.dll 5.0.14.15249 5.0.14.15249 5.0.14.15249 9/7/2015, 2:53 PM 89K
hw_xgate_burner_panel.dll 5.0.14.15249 5.0.14.15249 5.0.14.15249 9/7/2015, 2:53 PM 89K
hw_xgate_compiler_panel.dll 5.0.14.15249 5.0.14.15249 5.0.14.15249 9/7/2015, 2:53 PM 89K
hw_xgate_importer_panel.dll 5.0.14.15249 5.0.14.15249 5.0.14.15249 9/7/2015, 2:53 PM 89K
hw_xgate_libmaker_panel.dll 5.0.14.15249 5.0.14.15249 5.0.14.15249 9/7/2015, 2:53 PM 89K
hw_xgate_linker_panel.dll 5.0.14.15249 5.0.14.15249 5.0.14.15249 9/7/2015, 2:53 PM 89K
OsekPanel.dll 2, 1, 2, 0 2.1.2.0 2.1.2.0 8/29/2006, 8:41 PM 70K
PBatchRunnerPostLinker.dll 2.0.0 Build 0004 2.0.0.4 2.0.0.4 9/12/2003, 2:01 AM 39K
PBatchRunnerPreLinker.dll 1.0.0 build 0003 1.0.0.3 1.0.0.3 9/12/2003, 2:01 AM 29K
PCLintOptions.dll 1.5 1.5.0.5 1.5.0.5 9/4/2003, 7:28 PM 41K
PCLintSettings.dll 1.5 1.5.0.5 1.5.0.5 9/4/2003, 7:28 PM 82K
PDebugx86Except.dll 5.9 Build 5294 5.8.0.0 5.8.0.0 8/5/2010, 5:59 PM 64K
PExternalBuild.dll 1.0.1.0 1.0.1.0 1.0.1.0 8/5/2010, 5:58 PM 64K
pMWCVS.dll 1.3.0.5294 1.3.0.5294 1.3.0.5294 8/5/2010, 5:59 PM 64K
pmwSourceSafe.dll 5.5.1.40704 5.5.1.40704 5.5.1.40704 4/13/2004, 8:17 PM 29K
Bin\Plugins\Support
MWComHelpers.DLL 5.9.0 Build 5294 5.9.0.5294 5.9.0.5294 8/5/2010, 5:25 PM 460K
MWRadModel.dll 5.9.0 Build 5294 5.9.0.5294 5.9.0.5294 8/5/2010, 5:30 PM 572K
CPlusSourceGen.dll 5.9.0 Build 5294 5.9.0.5294 5.9.0.5294 8/5/2010, 5:43 PM 272K
MWComBase.dll 5.9.0 Build 5294 5.9.0.5294 5.9.0.5294 8/5/2010, 5:28 PM 64K
Bin\Plugins\version_control
mwcvs.dll 1.3.0.5294 1.3.0.5294 1.3.0.5294 8/5/2010, 5:59 PM 228K
mwSourceSafe.dll 1.0.3.716 1.0.3.716 1.0.3.716 4/13/2004, 8:17 PM 137K
VCSClearCase.dll 1.1.2.1999 1.1.2.1999 1.1.2.1999 9/29/2004, 7:58 PM 76K
Bin\resource
CPlusResources.dll 5.9.0 Build 5294 5.9.0.5294 5.9.0.5294 8/5/2010, 5:43 PM 24K
ExternalBuildResources.dll 5.9.0 Build 5294 5.9.0.5294 5.9.0.5294 8/5/2010, 5:58 PM 6K
IDEAuxiliaryResources.dll 5.9.0 Build 5294 5.9.0.5294 5.9.0.5294 8/5/2010, 5:25 PM 44K
IDEResources.dll 5.9.0 Build 5294 5.9.0.5294 5.9.0.5294 8/5/2010, 5:25 PM 52K
ErichStyger
Specialist I
I mean the about box of the simulator/debugger, not the IDE.
shiju_varghese
Could you please tell me exactly the name of the licence file ? In case not found the licence file, what is the next procedure?
ErichStyger
Specialist I
This shown in the About box too.
shiju_varghese
How can I check the the license file is valid or not? where is the exact location of licence file?
ErichStyger
Specialist I
As noted above: please check it in the About box of your application (e.g. Hi-Wave).
shiju_varghese
ErichStyger
Specialist I
To resolve the problem, you need to know what the problem is. In essence: you need a valid license, or that license needs to be found. There are many reasons why this problem can occur, from 'having deleted the license file', wrong configuration where the license file has been found' up to a time/date tampering has been detected. The FLEXlm/Licensing manual  included in the product should give you some guidance too.
stanleymcdon46
Erich Styger wrote:
To resolve the problem, you need to know what the problem is. In essence: you need a valid license, or that license needs to be found. There are many reasons why this problem can occur, from 'having deleted the license file', wrong configuration where dqfansurvey the license file has been found' up to a time/date tampering has been detected. The FLEXlm/Licensing manual  included in the product should give you some guidance too.
ok, sir will try that and let you know if anything happens.
ErichStyger
Specialist I
This means that your license has been expired or it cannot find the license file. What tells you the about box and the licensing status?
