Codewarrior/Kinetis design studio and plantuml integration
928 次查看
preethimahadeva
Has anyone successfully installed the plantuml plugin for Eclipse in Codewarrior/Kinetis design studio? Even after the plugin installation, I don't see the option in Windows->Show View.  When I try to update the plugin, it tells me there are dependencies that can't be resolved.
764 次查看
Carlos_Mendoza
Hi Preethi,
I have not used plantuml on CodeWarrior or KDS, but it should work if the plug in supports the eclipse version used as base for the IDE. How did you installed the plugin? make sure you followed this guide:
Integration with Eclipse
You could also check the plantuml Questions & Answers page and see if someone has encountered the same issues:
PlantUML Q&A
Hope it helps!
Carlos Mendoza
Technical Support Engineer
