Code Warrior 10.6 Licensing Issue
2,305 次查看
kiranbhat
I am using code warrior development suite professional with perpetual floating license. The license status is active but while compiling gives the error on code limit. Screen shot of the license status and the error is attached.
Kiran bhat
2,138 次查看
TICS_Fiona
Hello Kiran
There is some problem in your license installation.  Please follow the instructions in the attached document to install floating license.
If this does not help, would you please try to ping the IP address of the server? Whether the host can connect server? And also check whether the license server for CodeWarrior is started in FlexIM? Please also exit firewall on host.
I would suggest submitting a case. It's better under case process for private license details. For how to do it, please refer to:
https://community.freescale.com/docs/DOC-330215
Best Regards
Fiona Kuang
TIC - Technical Information Center
Note: If this post answers your question, please click the Mark Correct button. Thank you!
2,138 次查看
kiranbhat
Hi Fiona
Thanks for the support. I just changed the project workspace and it worked fine dont know the exact issue. This issue occurred 2 times in different PC's.
Kiran Bhat
