CW, Hierarchy problem
1,511 次查看
louishdy
I am a beginner with Code Warrior for my internship. I have problem when I load my project. It said that there is a problem with the hierarchy. Then, a new folder "Rescued Items" is created with some files (which had this problem).
Furthermore, some files are duplicated: when i chekched their path, they are from another project (the original one). Is it a problem with my makefile?
Thank you for you help.
1,398 次查看
TICS_Fiona
Hello Louis
For the problem of ‘Rescued Items’, please refer to this link, and review its attached doc < Rescued Items Whitepaper.doc>:
Codewarrior does not load the .lib file.
Best Regards
Fiona Kuang
TIC - Technical Information Center
Note: If this post answers your question, please click the Mark Correct button. Thank you!
