smd microcontroller programming
3,682 次查看
wolfgangs
Fresh Out Contributor
Hello everyone.  I would like to know how surface mount Freescale micro-controllers are programmed.  Does Freescale offer to do this at the factory?  Thanks.
2,397 次查看
weapon
Senior Contributor I
Hi Wolfgang,
Generally speaking, regading MCU programing,  there're two cases:
1. MCU is mounted on PCB before programed. In such case, Programmers can use a cable to connect to BDM port (for S08 ) on the board to program MCUs.  P&E provides such kind of programmers, for example P&E Cyclone Pro
http://www.pemicro.com/products/product_processor.cfm?category=12
2. We also can program MCUs  directly by some dedicated programmers, there are one or more sockets in
the programmer, Put MCUs in them, one GUI in PC side can control the programming.
For example, Hilo System provides such kind of programmers
http://www.hilosystems.com.tw/en/hilo_products/programmer.aspx
Hope those information will be helpful.
2,398 次查看
weapon
Hi Wolfgang,
