Free Master Poll();
Free Master Poll();
1,618件の閲覧回数
leang
Hi dears,
When i use FMSTR_Poll();
Dose FMSTR_Poll(); have to be executed twice to output correct results?
Well  i mean ,in the while(1)   ,the program have been executed once ,and the FMSTR_Poll() also  have been executed once. Will the value of the observation variable be transferred to the Freemaster ?
Because  when i was debugging the program i  found that ,for  the first time the  Poll  is  dealing with receiving data and decoding  and something, and the second time it will transmit data.
1,592件の閲覧回数
vicentegomez
 Normally when you are using Free master you do not need to debug, please check the following application note
https://www.nxp.com/webapp/Download?colCode=AN4752
