Alternate Compatibility
acoulbourn
Good afternoon, I need to confirm compatibility between 2 options for (Freescale /NXP ) Components.
The 1st version MCHC11F1VFNE4 and the second version MCHC11F1CFNE4.  I understand the differences are temperature ranges.  But fit form and function would be identical ?  What about for flashing /programming the chip,  would that also be the same?  between both versions.
Thank you in advance
Al Coulbourn
Flavor X
[email protected]
vicentegomez
yes, both parts have the same function, memory etc, the only difference is the range of operation temperature
