After TBM interrupt actice, can't return to mainloop
1,891 次查看
Simen
Dear ALL,
I use CodeWarrior to design MC68HC908GR4.
But I have a problem about using its TBM interrupt.
After the isrTBM active,it can't return to mainloop.
The program always run in isrTBM.
Any suggestion ?
Thanks a lot for help!
Attach file is Demo project,it can show the problem.
895 次查看
rocco
Senior Contributor II
Hi Simen, and welcome to the forum.
You need to clear the TBM interrupt, as it won't go away on its own.
To clear the interrupt flag, TBIF, you need to write a one to the TACK bit from within your interrupt service routine. Both of these bits are in the TBCR register.
895 次查看
Simen
Thanks a lot for your help,I have solved it!
