Deploying the eIQ Sample Apps to an i.MX8 board
After setting up an Yocto build environment as described in the L4.19.35_1.0.0 BSP Yocto Project User's Guide, apply the attached patch to the meta-fsl-bsp-release layer:
<yocto_dir>/sources/meta-fsl-bsp-release$ git am eiq-sample-apps-Add-recipe.patch
To include the applications in the image, add the following line to local.conf:
IMAGE_INSTALL_append += "eiq-sample-apps"
This will include all applications from the eIQ Sample Apps repository to the built image.
Tags (2)
Comments
Hello:
           I encounter a error when applied the attached patch.
ERROR: Nothing RPROVIDES 'eiq-sample-apps' (but /home/duxy/fsl-arm-yocto-bsp/sources/meta-fsl-bsp-release/imx/meta-sdk/dynamic-layers/qt5-layer/recipes-fsl/images/fsl-image-qt5.bb RDEPENDS on or otherwise requires it)
NOTE: Runtime target 'eiq-sample-apps' is unbuildable, removing...
Missing or unbuildable dependency chain was: ['eiq-sample-apps']
ERROR: Required build target 'fsl-image-qt5' has no buildable providers.
Missing or unbuildable dependency chain was: ['fsl-image-qt5', 'eiq-sample-apps']
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
      how to resolve it?    Before applied the patch, I have compiled the eIQ image successfully.
Hi coindu‌,
Could you please confirm that the patch was successfully applied? Does the eiq-sample-apps folder exists in meta-fsl-bsp-release/imx/meta-ml/recipes-apps/eiq-sample-apps? What BSP release are you using?
Thanks!
Vanessa
fsl-arm-yocto-bsp/sources/meta-fsl-bsp-release$ git log
commit 7a67a5a9f8bb31a50bf6704d6383957c8264c656
Author: Vanessa Maegima <[email protected]>
Date: Tue Oct 1 16:07:22 2019 -0300
eiq-sample-apps: Add recipe
Recipe to deploy all eiq_sample_apps to an iMX8* board.
Signed-off-by: Vanessa Maegima <[email protected]>
commit 8eeb420fad668b733ab95b460895e1c337c66b25
Author: Neena Busireddy <[email protected]>
Date: Fri May 3 10:50:12 2019 -0500
vkmark: Use SHA in SRCREV instead of AUTOREV
Signed-off-by: Neena Busireddy <[email protected]>
I reference 《UM11226.pdf》 to set the environment
repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-sumo -m imx-4.14.98-2.0.0_machinelearning.xml
$: EULA=1 MACHINE=imx8mqevk DISTRO=fsl-imx-xwayland source ./fsl-setup-release.sh -b build-xwayland $: echo "BBLAYERS += \" \${BSPDIR}/sources/meta-imx-machinelearning \"" >> conf/bblayers.conf
meta-imx-machinelearning/recipes-libraries/tensorflow/tensorflow_1.12.0.bb  modify
COMPATIBLE_MACHINE = "(imx8qm|imx8mq|imx8mm)"
bitbake fsl-image-qt5
Could you please modify the COMPATIBLE_MACHINE in the eiq_sample_apps recipe as you did for TensorFlow and let me know how it goes?
My patch applies on top of a newer release L4.19.35 but let's try to make this work on L4.14.98
It do not work to modify COMPATIBLE_MACHINE.
It doesn't matter, I still compile according to the documentation
Please try adding the following line to conf/bblayers.conf:
BBLAYERS += " ${BSPDIR}/sources/meta-fsl-bsp-release/imx/meta-ml "
The Yocto Project User's Guide say that eIQ is integrated in meta-eiq, but this layer doesn't exist.
There is a meta-ml: is ti the same thing?
Philippe
Hi philippemidol-monnet‌,
Yes, you are correct. I will ask for this to be updated.
Thanks for reporting.
Vanessa
%3CLINGO-SUB%20id%3D%22lingo-sub-1103034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDeploying%20the%20eIQ%20Sample%20Apps%20to%20an%20i.MX8%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAfter%20setting%20up%20an%20Yocto%20build%20environment%20as%20described%20in%20the%20L4.19.35_1.0.0%20BSP%20Yocto%20Project%20User's%20Guide%2C%20apply%20the%20attached%20patch%20to%20the%20%3CSTRONG%3Emeta-fsl-bsp-release%3C%2FSTRONG%3E%20layer%3A%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%3CYOCTO_DIR%3E%2Fsources%2Fmeta-fsl-bsp-release%24%20git%20am%20eiq-sample-apps-Add-recipe.patch%3C%2FYOCTO_DIR%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3ETo%20include%20the%20applications%20in%20the%20image%2C%20add%20the%20following%20line%20to%20%3CSTRONG%3Elocal.conf%3C%2FSTRONG%3E%3A%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3EIMAGE_INSTALL_append%20%2B%3D%20%22eiq-sample-apps%22%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3EThis%20will%20include%20all%20applications%20from%20the%20%3CA%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimxsupport%2Feiq_sample_apps%2Ftree%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EeIQ%20Sample%20Apps%20repository%3C%2FA%3E%20to%20the%20built%20image.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1103034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103042%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Deploying%20the%20eIQ%20Sample%20Apps%20to%20an%20i.MX8%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103042%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fphilippemidol-monnet%22%20target%3D%22_blank%22%3Ephilippemidol-monnet%3C%2FA%3E%E2%80%8C%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EYes%2C%20you%20are%20correct.%20I%20will%20ask%20for%20this%20to%20be%20updated.%20%3CBR%20%2F%3E%3CBR%20%2F%3EThanks%20for%20reporting.%3C%2FP%3E%3CP%3EVanessa%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Deploying%20the%20eIQ%20Sample%20Apps%20to%20an%20i.MX8%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%26nbsp%3B%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EYocto%20Project%20User's%20Guide%20say%20that%20eIQ%20is%20integrated%20in%20meta-eiq%2C%20but%20this%20layer%20doesn't%20exist.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EThere%20is%20a%20meta-ml%3A%20is%20ti%20the%20same%20thing%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EPhilippe%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103040%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Deploying%20the%20eIQ%20Sample%20Apps%20to%20an%20i.MX8%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103040%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPlease%20try%20adding%20the%20following%20line%20to%20%3CEM%3Econf%2Fbblayers.conf%3C%2FEM%3E%3A%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3EBBLAYERS%20%2B%3D%20%22%20%24%7BBSPDIR%7D%2Fsources%2Fmeta-fsl-bsp-release%2Fimx%2Fmeta-ml%20%22%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Deploying%20the%20eIQ%20Sample%20Apps%20to%20an%20i.MX8%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIt%20do%20not%20work%20to%20modify%20COMPATIBLE_MACHINE.%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3EIt%20doesn't%20matter%2C%20I%20still%20compile%20according%20to%20the%20documentation%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103038%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Deploying%20the%20eIQ%20Sample%20Apps%20to%20an%20i.MX8%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103038%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ECould%20you%20please%20modify%20the%20COMPATIBLE_MACHINE%20in%20the%20eiq_sample_apps%20recipe%20as%20you%20did%20for%20TensorFlow%20and%20let%20me%20know%20how%20it%20goes%3F%3C%2FP%3E%3CPRE%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23f6f8fa%3B%20border%3A%200px%3B%20margin%3A%200px%200px%2016px%3B%20padding%3A%2016px%3B%22%3E%3CCODE%20class%3D%22%22%20style%3D%22color%3A%20%23333333%3B%20background%3A%20transparent%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3ECOMPATIBLE_MACHINE%3C%2FSPAN%3E%20%3D%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23dd1144%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%22(imx8qm%7Cimx8mq%7Cimx8mm)%22%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3EMy%20patch%20applies%20on%20top%20of%20a%20newer%20release%20L4.19.35%20but%20let's%20try%20to%20make%20this%20work%20on%20L4.14.98%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Deploying%20the%20eIQ%20Sample%20Apps%20to%20an%20i.MX8%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Efsl-arm-yocto-bsp%2Fsources%2Fmeta-fsl-bsp-release%24%20git%20log%3C%2FP%3E%3CP%3Ecommit%207a67a5a9f8bb31a50bf6704d6383957c8264c656%3CBR%20%2F%3E%3CSPAN%3EAuthor%3A%20Vanessa%20Maegima%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Avanessa.maegima%40nxp.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Evanessa.maegima%40nxp.com%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CBR%20%2F%3EDate%3A%20Tue%20Oct%201%2016%3A07%3A22%202019%20-0300%3C%2FP%3E%3CP%3Eeiq-sample-apps%3A%20Add%20recipe%3CBR%20%2F%3E%3CBR%20%2F%3E%20Recipe%20to%20deploy%20all%20eiq_sample_apps%20to%20an%20iMX8*%20board.%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%20Signed-off-by%3A%20Vanessa%20Maegima%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Avanessa.maegima%40nxp.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Evanessa.maegima%40nxp.com%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Ecommit%208eeb420fad668b733ab95b460895e1c337c66b25%3CBR%20%2F%3E%3CSPAN%3EAuthor%3A%20Neena%20Busireddy%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Aneenareddy.busireddy%40nxp.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eneenareddy.busireddy%40nxp.com%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CBR%20%2F%3EDate%3A%20Fri%20May%203%2010%3A50%3A12%202019%20-0500%3C%2FP%3E%3CP%3Evkmark%3A%20Use%20SHA%20in%20SRCREV%20instead%20of%20AUTOREV%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%20Signed-off-by%3A%20Neena%20Busireddy%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Aneenareddy.busireddy%40nxp.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eneenareddy.busireddy%40nxp.com%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20869px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F95238iE5ABE8016CEE8D42%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20reference%20%E3%80%8AUM11226.pdf%E3%80%8B%20to%20set%20the%26nbsp%3Benvironment%3C%2FP%3E%3CPRE%20style%3D%22color%3A%20%2324292e%3B%20background-color%3A%20%23f6f8fa%3B%20margin-bottom%3A%2016px%3B%20padding%3A%2016px%3B%22%3E%3CCODE%20class%3D%22%22%20style%3D%22color%3A%20%23333333%3B%20background%3A%20transparent%3B%20border%3A%200px%3B%22%3Erepo%20init%20-u%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23990073%3B%22%3Ehttps%3A%3C%2FSPAN%3E%2F%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23009926%3B%22%3E%2Fsource.codeaurora.org%2Fexternal%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23009926%3B%22%3E%2Fimx%2Fimx%3C%2FSPAN%3E-manifest%20-b%20imx-linux-sumo%20-m%20imx-%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008080%3B%22%3E4.14%3C%2FSPAN%3E.%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008080%3B%22%3E98%3C%2FSPAN%3E-%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008080%3B%22%3E2.0%3C%2FSPAN%3E.%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008080%3B%22%3E0_%3C%2FSPAN%3Emachinelearning.xml%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22color%3A%20%2324292e%3B%20background-color%3A%20%23f6f8fa%3B%20margin-bottom%3A%2016px%3B%20padding%3A%2016px%3B%22%3E%3CCODE%20class%3D%22%22%20style%3D%22color%3A%20%23333333%3B%20background%3A%20transparent%3B%20border%3A%200px%3B%22%3E%24%3A%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23000080%3B%20font-weight%3A%20normal%3B%22%3EEULA%3C%2FSPAN%3E%3D1%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23000080%3B%20font-weight%3A%20normal%3B%22%3EMACHINE%3C%2FSPAN%3E%3Dimx8mqevk%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23000080%3B%20font-weight%3A%20normal%3B%22%3EDISTRO%3C%2FSPAN%3E%3Dfsl-imx-xwayland%20source%20.%2Ffsl-setup-release.sh%20-b%20build-xwayland%20%24%3A%20echo%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23dd1144%3B%22%3E%22BBLAYERS%20%2B%3D%20%5C%22%20%5C%24%7BBSPDIR%7D%2Fsources%2Fmeta-imx-machinelearning%20%5C%22%22%3C%2FSPAN%3E%20%26gt%3B%26gt%3B%20conf%2Fbblayers.conf%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2324292e%3B%22%3Emeta-imx-machinelearning%2Frecipes-libraries%2Ftensorflow%2Ftensorflow_1.12.0.bb%26nbsp%3B%20modify%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20style%3D%22background-color%3A%20%23f6f8fa%3B%20margin-bottom%3A%2016px%3B%20padding%3A%2016px%3B%22%3E%3CCODE%20class%3D%22%22%20style%3D%22color%3A%20%23333333%3B%20background%3A%20transparent%3B%20border%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%3ECOMPATIBLE_MACHINE%3C%2FSPAN%3E%20%3D%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23dd1144%3B%22%3E%22(imx8qm%7Cimx8mq%7Cimx8mm)%22%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2324292e%3B%22%3Ebitbake%20fsl-image-qt5%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Deploying%20the%20eIQ%20Sample%20Apps%20to%20an%20i.MX8%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fcoindu%22%20target%3D%22_blank%22%3Ecoindu%3C%2FA%3E%E2%80%8C%2C%3C%2FP%3E%3CP%3ECould%20you%20please%20confirm%20that%20the%20patch%20was%20successfully%20applied%3F%20Does%20the%20eiq-sample-apps%20folder%20exists%20in%20%3CEM%3Emeta-fsl-bsp-release%2Fimx%2Fmeta-ml%2Frecipes-apps%2Feiq-sample-apps%3C%2FEM%3E%3F%20What%20BSP%20release%20are%20you%20using%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks!%3C%2FP%3E%3CP%3EVanessa%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Deploying%20the%20eIQ%20Sample%20Apps%20to%20an%20i.MX8%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BI%20encounter%20a%20error%20when%26nbsp%3B%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3Eapplied%20the%20attached%20patch.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EERROR%3A%20Nothing%20RPROVIDES%20'eiq-sample-apps'%20(but%20%2Fhome%2Fduxy%2Ffsl-arm-yocto-bsp%2Fsources%2Fmeta-fsl-bsp-release%2Fimx%2Fmeta-sdk%2Fdynamic-layers%2Fqt5-layer%2Frecipes-fsl%2Fimages%2Ffsl-image-qt5.bb%20RDEPENDS%20on%20or%20otherwise%20requires%20it)%3CBR%20%2F%3ENOTE%3A%20Runtime%20target%20'eiq-sample-apps'%20is%20unbuildable%2C%20removing...%3CBR%20%2F%3EMissing%20or%20unbuildable%20dependency%20chain%20was%3A%20%5B'eiq-sample-apps'%5D%3CBR%20%2F%3EERROR%3A%20Required%20build%20target%20'fsl-image-qt5'%20has%20no%20buildable%20providers.%3CBR%20%2F%3EMissing%20or%20unbuildable%20dependency%20chain%20was%3A%20%5B'fsl-image-qt5'%2C%20'eiq-sample-apps'%5D%3C%2FP%3E%3CP%3ESummary%3A%20There%20were%202%20ERROR%20messages%20shown%2C%20returning%20a%20non-zero%20exit%20code.%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20how%20to%20resolve%20it%3F%26nbsp%3B%20%26nbsp%3B%20Before%20applied%20the%20patch%EF%BC%8C%20I%20have%20compiled%20the%20eIQ%20image%26nbsp%3Bsuccessfully.%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎11-26-2019 06:41 AM
Updated by:
