The article you are trying to access is permanently deleted.
Product Release Announcement Automotive Microcontrollers and Processors S32 Design Studio for Power Architecture 2017.R1 Update 10 |
The update is available for online installation (via S32DS Eclipse Updater) or offline installation (direct download link)
Select all available items and click "Next" button.
This will start the update installation process.
When performing the above steps for online installation, selecting all components for update, I get a number of warnings, saying that certain components will not be installed.
Is that OK?
I started the install that had the warnings and got an installation error:
So we cannot install the update. What are our options? We wanted to install the update to prevent 'reset escalation' problems discussed in many places in this forum.
Finally I tried the offline-install. This fails with the same error as above.
I performed a deinstallation of the system.
Then a new installation, but this time I kept the default settings for the installation position.
This worked without any errors.
(When I did the first install, I Installed to 'c:\Program Files\NXP' instead of the default C:\NXP.)
