GDB server stuck, eval board MTRCKTSPS5744P
patel_reddy
Built project for eval board, MTRCKTSPS5744P, from inbuilt examples as per link in Getting Started with MTRCKTSPS5744P | NXP .
However during download process, the debug process stuck at 98%, ERROR seems to be at CRC mismatch.
Lync
When I tried to download the resource for MPC5744P Development Kit, i.e. MTRCKTSPS5744P development kit RevB - PCB and MTRCKTSPS5744P development kit RevC - PCB, it failed.
Is there any way to download the resource?
patel_reddy
Using SD32 PA 2.1, made changes to redirect the tools, so able to successfully execute example code, however adding another initialization is creating havoc with CRC.
SUCCESS
STUCK AT 98%
