Why did printf() stop working?
mbra16
I'm developing some software for the LPC804. In that regard I use MCUXpresso v11.
Yesturday I was working on my project, and printf() was doing what it's supposed to without a problem. After work I saved, closed, and turned off my computer. Today when I wanted to continue working, printf() did not show up in the console.
I tried making a new project and run it to see if it was some configuration in my current project that I messed up. To my surprise, it wasn't. The printf("hello world"); did not work in the new project either.
I can confirm I have selected Semihosting when making the project, and that the console writes "Awaiting telnet connection to port 3330 ..." when I initiate the debugging.
Is there anything obvious I'm missing?
Tags (2)
Alexis_A
Hi Martin,
I will suggest to check the following post. Here explain a similar problem.
Alexis Andalon
mbra16
Thanks. While debugging configurations I found that the SDK Debug Console was set to UART. When I put it back to Semihost, it worked again. I wonder how it got changed in the first place, but my problem is resolved for now.
Alexis_A
Hi Martin,
I'm glad that you could solve your issue and thanks for sharing your solution.
Alexis Andalon
