NXP LPC54018 IoT Module & AWS IoT
saranyachitta
I've started working with LPC 54018 & AWS IoT. I've followed all the step-by-step instructions as mentioned in the tutorial for the aws_shadow_wifi example (OM40007|LPC54018 IoT Microcontroller Module|NXP). This demo works fine and I see all the MQTT commands in the Serial Terminal (Tera Term).
However, I tried the voice control demonstration example (aws-nxp-lpc54018-demo/README.md at master · bluewind-embedded-systems/aws-nxp-lpc54018-demo · GitHub) by following all the step-by-step instructions as mentioned in the respective Read-me files. But, I don't see the communication going well. I only receive the following commands as shown in the screenshot below from my Serial Terminal (Tera Term). Could you please advise me on what else to try in order to avoid this issue? Any help would be greatly appreciated.
Thank you,
Saranya
saranyachitta
Sol,
That works perfectly fine now. Thank you so much for your help all through the process. You were very helpful and I really appreciate it.
Saranya
soledad
Please check the attached document and let me know if this helps.
Sol
saranyachitta
I have a quick question regarding this document. It asks me to copy the code from few files like -
1. LED_lambda_function.py
2. Alexa_json_skill.json
Could you please let me know where can I find them. If you can please send me those files or a link to download them, that would be grateful.
Thank you,
Saranya
soledad
Attached you will find the files.
Sol
