LPC54608 USB DFU function support
timhuang
I have a question about LPC54608 USB DFU.
Could you know how to get the example code of LPC54608 USB DFU.
Because I see the below picture( UM10912.pdf )
LPC54608 can support USB DFU, but I can't find any example code for reference, could you give some suggestion to us how to implement it?
Thanks for your help.
Tags (2)
victorjimenez
Hello all,
Please find attached the example project here.
Victor.
arno1
victorjimenez‌, can you please publish the example code?
victorjimenez
The apps team is currently working on an example of USB DFU mode for the LPC546xx families. It is expected to be ready within the next 2 or 3 weeks. I will let you know when this example is available.
Victor.
vfperri
Hi victorjimenez,
I'm writting you because I want to know if the example project is available.
Thanks!!,
Victor Perri
benmao
Is the example already available?
timhuang
OK, Thanks for your quick reply.
victorjimenez
Hello timhuang,
Thanks for your patience. I just sent you to your email the example project.
Hope it helps!
Victor.
travis_scott
Hi there, we are also interested in this example. Can you please provide it?
