how S32 with PowerPC to generate library file(*.a file)
翔刘11
how S32 with PowerPC to generate library file(*.a file) ?
Tags (3)
stanish
I assume you want to build the library from S32DS IDE.
The New project wizard allows you to chose between application or library:
Hope it helps.
Stan
翔刘11
@Stanislav Sliva 员工  Thank you for your reply ,You are the best
stanish
Hope it helps.
Stan
