How do I use the NMI (Nonmaskable interrupt) for MPC5744P?
gerrywang
In our project, when the interrupt condition occurs, the SBC (FS6500) generates a low pulse to the NMI pin of the MPC5744P. However, I do not know how to configure and implement Nonmaskable interrupt in code, there are examples of code?
Tags (3)
petervlna
This is quite simple.
When NMI is rised micro is going into machine check exception like e200z4 reference manual shows below:
To serve NMI you need to have IVOR1 handler. As an example you can refer to one of the the MPC5744P examples with IVOR handlers implemented we have posted here:
MPC5 software example list
for example:
https://community.nxp.com/docs/DOC-103438
Peter
gerrywang
Hi , Peter
Thank you for your reply!
But I'm not familiar with VLE instruction set. Can you provide an example of an IVOR1 handler?
petervlna
You can find reference example for IVOR1 here:
https://community.nxp.com/docs/DOC-333754
Peter
alexanderhu
hi,peter:
      Is there an example of working in S32D?
