using QSPI for interfacing a sensor using imxrt1170 evkb board
Ruthvik_R
Hi all ,
we are using a mimxrt1170 evkb board for our developement purpose . In this board the QSPi is used for flash the meory by default. i would like to know if it is possible to use the qspi for the purpose of interfacing a sensor that communicates using qspi by using a different flash method. is this possible in the evk kit and is there support for this on zephyr as our eventual application will be a zephyr application.
Thank you
Sam_Gao
@Ruthvik_R
Q1: if it is possible to use the qspi for the purpose of interfacing a sensor that communicates using qspi by using a different flash method.
--> No, there are two FlexSPI interface ports(A and B), FlexSPI supports communication with both serial flash memory and serial RAM devices, it is dedicated for external memory device.
Q2: is this possible in the evk kit and is there support for this on zephyr as our eventual application will be a zephyr application.
--> FlexSPI is used for is25wp128, its dtsi shows: https://github.com/zephyrproject-rtos/zephyr/blob/main/boards/nxp/mimxrt1170_evk/mimxrt1170_evk.dtsi...
Sam_Gao
@Ruthvik_R
%3CLINGO-SUB%20id%3D%22lingo-sub-2088970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eusing%20QSPI%20for%20interfacing%20a%20sensor%20using%20imxrt1170%20evkb%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2088970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20all%20%2C%3C%2FP%3E%3CP%3Ewe%20are%20using%20a%20mimxrt1170%20evkb%20board%20for%20our%20developement%20purpose%20.%20In%20this%20board%20the%20QSPi%20is%20used%20for%20flash%20the%20meory%20by%20default.%20i%20would%20like%20to%20know%20if%20it%20is%20possible%20to%20use%20the%20qspi%20for%20the%20purpose%20of%20interfacing%20a%20sensor%20that%20communicates%20using%20qspi%20by%20using%20a%20different%20flash%20method.%20is%20this%20possible%20in%20the%20evk%20kit%20and%20is%20there%20support%20for%20this%20on%20zephyr%20as%20our%20eventual%20application%20will%20be%20a%20zephyr%20application.%3C%2FP%3E%3CP%3EThank%20you%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2089812%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20using%20QSPI%20for%20interfacing%20a%20sensor%20using%20imxrt1170%20evkb%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2089812%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F249934%22%20target%3D%22_blank%22%3E%40Ruthvik_R%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EQ1%3A%20if%20it%20is%20possible%20to%20use%20the%20qspi%20for%20the%20purpose%20of%20interfacing%20a%20sensor%20that%20communicates%20using%20qspi%20by%20using%20a%20different%20flash%20method.%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20color%3D%22%230000FF%22%3E%3CSPAN%3E--%26gt%3B%20No%2C%20there%20are%20two%20FlexSPI%20interface%20ports(A%20and%20B)%2C%20FlexSPI%20supports%20communication%20with%20both%20serial%20flash%20memory%20and%20serial%20RAM%20devices%2C%26nbsp%3Bit%20is%20%3CSTRONG%3Ededicated%3C%2FSTRONG%3E%20for%20external%20%3CSTRONG%3Ememory%3C%2FSTRONG%3E%20%3CSTRONG%3Edevice%3C%2FSTRONG%3E.%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EQ2%3A%20is%20this%20possible%20in%20the%20evk%20kit%20and%20is%20there%20support%20for%20this%20on%20zephyr%20as%20our%20eventual%20application%20will%20be%20a%20zephyr%20application.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20color%3D%22%230000FF%22%3E%3CSPAN%3E--%26gt%3B%20FlexSPI%20is%20used%20for%26nbsp%3Bis25wp128%2C%20its%20dtsi%20shows%3A%26nbsp%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fzephyrproject-rtos%2Fzephyr%2Fblob%2Fmain%2Fboards%2Fnxp%2Fmimxrt1170_evk%2Fmimxrt1170_evk.dtsi%23L215C2-L215C9%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fzephyrproject-rtos%2Fzephyr%2Fblob%2Fmain%2Fboards%2Fnxp%2Fmimxrt1170_evk%2Fmimxrt1170_evk.dtsi%23L215C2-L215C9%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
