using QSPI for interfacing a sensor using imxrt1170 evkb board
1,264 次查看
Ruthvik_R
Hi all ,
we are using a mimxrt1170 evkb board for our developement purpose . In this board the QSPi is used for flash the meory by default. i would like to know if it is possible to use the qspi for the purpose of interfacing a sensor that communicates using qspi by using a different flash method. is this possible in the evk kit and is there support for this on zephyr as our eventual application will be a zephyr application.
Thank you
标记 (1)
1,240 次查看
Sam_Gao
@Ruthvik_R
Q1: if it is possible to use the qspi for the purpose of interfacing a sensor that communicates using qspi by using a different flash method.
--> No, there are two FlexSPI interface ports(A and B), FlexSPI supports communication with both serial flash memory and serial RAM devices, it is dedicated for external memory device.
Q2: is this possible in the evk kit and is there support for this on zephyr as our eventual application will be a zephyr application.
--> FlexSPI is used for is25wp128, its dtsi shows: https://github.com/zephyrproject-rtos/zephyr/blob/main/boards/nxp/mimxrt1170_evk/mimxrt1170_evk.dtsi...
1,241 次查看
Sam_Gao
@Ruthvik_R
%3CLINGO-SUB%20id%3D%22lingo-sub-2088970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%20QSPI%20%E8%BF%9E%E6%8E%A5%E4%BD%BF%E7%94%A8%20imxrt1170%20evkb%20%E6%9D%BF%E7%9A%84%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2088970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%20%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20mimxrt1170%20evkb%20%E6%9D%BF%E8%BF%9B%E8%A1%8C%E5%BC%80%E5%8F%91%E3%80%82%E5%9C%A8%E6%AD%A4%E6%9D%BF%E4%B8%AD%EF%BC%8CQSPi%20%E9%BB%98%E8%AE%A4%E7%94%A8%E4%BA%8E%E5%88%B7%E6%96%B0%E7%90%86%E8%AE%BA%E3%80%82%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20qspi%20%E6%9D%A5%E8%BF%9E%E6%8E%A5%E4%BD%BF%E7%94%A8%20qspi%20%E8%BF%9B%E8%A1%8C%E9%80%9A%E4%BF%A1%E7%9A%84%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%88%E9%80%9A%E8%BF%87%E4%BD%BF%E7%94%A8%E4%B8%8D%E5%90%8C%E7%9A%84%E9%97%AA%E5%AD%98%E6%96%B9%E6%B3%95%EF%BC%89%E3%80%82%E8%BF%99%E5%9C%A8%20evk%20%E5%A5%97%E4%BB%B6%E4%B8%AD%E6%98%AF%E5%90%A6%E5%8F%AF%E8%A1%8C%EF%BC%8CZephyr%20%E6%98%AF%E5%90%A6%E6%94%AF%E6%8C%81%E8%BF%99%E4%B8%80%E7%82%B9%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E4%BB%AC%E7%9A%84%E6%9C%80%E7%BB%88%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%B0%86%E6%98%AF%20Zephyr%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E
