[i.MX RT1040 EVK] SAI EDMA Local Loopback Issue: RX buffer data shifted by 4 bytes
1,110件の閲覧回数
nikonz66
Hi NXP Team,
I am currently working on the official i.MX RT1040 EVK and trying to use the SAI interface for custom pure data transfer (not standard audio). To verify my logic, I am performing a Local Loopback Test by physically shorting the SAI TX and RX pins on the EVK, completely bypassing the external audio codec.I want to use the I2S (SAI) interface as a high-speed communication peripheral for pure data transfer (not standard audio) and encapsulate it into a custom communication driver layer. I am currently in the testing phase verifying the basic logic.
I initialized the SAI to work in classic I2S master mode (generating BCLK and SYNC internally) and used SAI_TransferSendEDMA() and SAI_TransferReceiveEDMA() with a buffer size of 128 bytes.
When I populate my tx_buffer starting with 0xAA (e.g., [0xAA, 0x01, 0x02, ...]) and start the DMA transfers, the rx_buffer receives the data, but the entire payload is shifted by 4 bytes. Specifically:
1   rx_buffer[0] to rx_buffer[3] are always 0x00.
2   My actual first byte 0xAA appears at rx_buffer[4].
3   The rest of the data follows sequentially, which means the last 4 bytes of my payload are truncated/lost because the DMA transfer size is strictly 128 bytes.
(Please see the attached Keil debug screenshot showing the tx_buffer and rx_buffer memory windows.)
Any guidance or reference code would be greatly appreciated. Thank you!
1,033件の閲覧回数
nikonz66
solved
If both the transmitter and receiver use the transmitter bit clock and frame sync:
• Configure the transmitter for asynchronous operation and the receiver for
synchronous operation.
• Enable the receiver in synchronous mode only after both the transmitter and receiver
are enabled.
• Enable the transmitter last and disable the tranmitter first.
%3CLINGO-SUB%20id%3D%22lingo-sub-2331478%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5Bi.MX%20RT1040%20EVK%5D%20SAI%20EDMA%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%E3%81%AE%E5%95%8F%E9%A1%8C%EF%BC%9ARX%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C4%E3%83%90%E3%82%A4%E3%83%88%E3%82%B7%E3%83%95%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2331478%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81NXP%20%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AE%E7%9A%86%E6%A7%98%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%80%81%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%85%AC%E5%BC%8Fi.MX%20RT1040%20EVK%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81SAI%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%EF%BC%88%E6%A8%99%E6%BA%96%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%EF%BC%89%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%81%AE%E7%B4%94%E7%B2%8B%E3%81%AA%E3%83%87%E3%83%BC%E3%82%BF%E8%BB%A2%E9%80%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AE%E8%AB%96%E7%90%86%E3%82%92%E6%A4%9C%E8%A8%BC%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E7%A7%81%E3%81%AF%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%E3%83%86%E3%82%B9%E3%83%88%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3EEVK%E3%81%AESAI%20TX%E3%83%94%E3%83%B3%E3%81%A8RX%E3%83%94%E3%83%B3%E3%82%92%E7%89%A9%E7%90%86%E7%9A%84%E3%81%AB%E7%9F%AD%E7%B5%A1%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E5%A4%96%E9%83%A8%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%82%92%E5%AE%8C%E5%85%A8%E3%81%AB%E3%83%90%E3%82%A4%E3%83%91%E3%82%B9%E3%81%97%E3%81%BE%E3%81%99%E3%80%82I2S%20%3CSPAN%3E%EF%BC%88SAI%EF%BC%89%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E3%80%81%E7%B4%94%E7%B2%8B%E3%81%AA%E3%83%87%E3%83%BC%E3%82%BF%E8%BB%A2%E9%80%81%EF%BC%88%E6%A8%99%E6%BA%96%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%EF%BC%89%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E9%AB%98%E9%80%9F%E9%80%9A%E4%BF%A1%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E9%80%9A%E4%BF%A1%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E5%B1%A4%E3%81%AB%E3%82%AB%E3%83%97%E3%82%BB%E3%83%AB%E5%8C%96%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%80%81%E5%9F%BA%E6%9C%AC%E7%9A%84%E3%81%AA%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%82%92%E6%A4%9C%E8%A8%BC%E3%81%99%E3%82%8B%E3%83%86%E3%82%B9%E3%83%88%E6%AE%B5%E9%9A%8E%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ESAI%E3%82%92%E3%82%AF%E3%83%A9%E3%82%B7%E3%83%83%E3%82%AFI2S%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%A2%E3%83%BC%E3%83%89%EF%BC%88%E5%86%85%E9%83%A8%E3%81%A7BCLK%E3%81%A8SYNC%E3%82%92%E7%94%9F%E6%88%90%EF%BC%89%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%80%81%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3ESAI_TransferSendEDMA()%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%E3%81%9D%E3%81%97%E3%81%A6%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3ESAI_TransferReceiveEDMA()%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF128%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Etx_buffer%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%81%8B%E3%82%89%E5%A7%8B%E3%81%BE%E3%82%8B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E0xAA%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%EF%BC%88%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%5B0xAA%E3%80%810x01%E3%80%810x02%E3%80%81...%5D)%20%E3%81%A8%20DMA%20%E8%BB%A2%E9%80%81%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%80%81%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Erx_buffer%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E5%8F%97%E4%BF%A1%E3%81%95%E3%82%8C%E3%82%8B%E3%81%8C%E3%80%81%E3%83%9A%E3%82%A4%E3%83%AD%E3%83%BC%E3%83%89%E5%85%A8%E4%BD%93%E3%81%8C4%E3%83%90%E3%82%A4%E3%83%88%E3%81%9A%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%80%82%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AB%E3%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E1%20rx_buffer%5B0%5D%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%81%AB%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Erx_buffer%5B3%5D%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%81%84%E3%81%A4%E3%82%82%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E0x00%E3%80%82%3C%2FP%3E%3CP%3E2%20%E7%A7%81%E3%81%AE%E5%AE%9F%E9%9A%9B%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%90%E3%82%A4%E3%83%88%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E0xAA%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Erx_buffer%5B4%5D%E3%80%82%3C%2FP%3E%3CP%3E3%20%E6%AE%8B%E3%82%8A%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E9%A0%86%E6%AC%A1%E7%B6%9A%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81DMA%E8%BB%A2%E9%80%81%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C%E5%8E%B3%E5%AF%86%E3%81%AB128%E3%83%90%E3%82%A4%E3%83%88%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%83%9A%E3%82%A4%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AE4%E3%83%90%E3%82%A4%E3%83%88%E3%81%AF%E5%88%87%E3%82%8A%E6%8D%A8%E3%81%A6%2F%E5%A4%B1%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%EF%BC%88%E6%B7%BB%E4%BB%98%E3%81%AEKeil%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%81%AB%E3%81%AF%E3%80%81tx_buffer%E3%81%A8rx_buffer%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E3%81%94%E5%8F%82%E7%85%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%EF%BC%89%3CBR%20%2F%3E%E4%BD%95%E3%81%8B%E3%81%94%E5%8A%A9%E8%A8%80%E3%82%84%E5%8F%82%E8%80%83%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E5%A4%A7%E5%A4%89%E3%81%82%E3%82%8A%E3%81%8C%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CEM%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2332262%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5Bi.MX%20RT1040%20EVK%5D%20SAI%20EDMA%20Local%20Loopback%20Issue%3A%20RX%20buffer%20data%20shifted%20by%204%20bytes%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2332262%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A7%A3%E6%B1%BA%E6%B8%88%E3%81%BF%3CBR%20%2F%3E%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9F%E3%83%83%E3%82%BF%E3%81%A8%E3%83%AC%E3%82%B7%E3%83%BC%E3%83%90%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%8C%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9F%E3%83%83%E3%82%BF%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A8%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E5%90%8C%E6%9C%9F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%EF%BC%9A%3CBR%20%2F%3E%20%E2%80%A2%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9F%E3%83%83%E3%82%BF%E3%82%92%E9%9D%9E%E5%90%8C%E6%9C%9F%E5%8B%95%E4%BD%9C%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81%E3%83%AC%E3%82%B7%E3%83%BC%E3%83%90%E3%82%92%3CBR%20%2F%3E%E5%90%8C%E6%9C%9F%E5%8B%95%E4%BD%9C%E3%80%82%3CBR%20%2F%3E%E3%83%BB%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9F%E3%83%83%E3%82%BF%E3%81%A8%E3%83%AC%E3%82%B7%E3%83%BC%E3%83%90%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%8C%E5%90%8C%E6%9C%9F%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%9F%E5%BE%8C%E3%81%AB%E3%81%AE%E3%81%BF%E3%80%81%E3%83%AC%E3%82%B7%E3%83%BC%E3%83%90%E3%82%92%E5%90%8C%E6%9C%9F%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%80%82%3CBR%20%2F%3E%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%BB%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9F%E3%83%83%E3%82%BF%E3%81%AF%E6%9C%80%E5%BE%8C%E3%81%AB%E6%9C%89%E5%8A%B9%E5%8C%96%E3%81%97%E3%80%81%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%9F%E3%83%83%E3%82%BF%E3%81%AF%E6%9C%80%E5%88%9D%E3%81%AB%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
