free rtos debugging in mcu xpresso runtime
2,027件の閲覧回数
jinu_mohan
hi ,
i had enabled the free rtos functions in mcu xpresso to monitor the behaviour of threads i'm able to get the run time but i need to convert this into seconds how to convert it
im getting the runtime in hex values need to convert this values to seconds how to do that.?
@kerryzhou
4 返答(返信)
2,005件の閲覧回数
jinu_mohan
Hi ,
Thanks for the update
Is there any tools in MCU xpresso to check the run timing of RTOS threads.?
@kerryzhou
2,004件の閲覧回数
kerryzhou
Hi @jinu_mohan ,
  You can use the code to collect it:
https://www.freertos.org/rtos-run-time-stats.html
   vTaskGetRunTimeStats() API can help you to collect the time.
Please also check this post:
https://community.nxp.com/t5/MCUXpresso-IDE/FreeRTOS-runtime-stats/m-p/1067434
Wish it helps you!
Kerry
2,012件の閲覧回数
kerryzhou
Hi @jinu_mohan ,
  I checked the MCUXpresso IDE related document:
C:\nxp\MCUXpressoIDE_11.5.0_7232\MCUXpresso_IDE_FreeRTOS_Debug_Guide.pdf
It is the percentage value, so, it should can't change to the seconds, more details, you also can check the above IDE document.
Kerry
2,021件の閲覧回数
jinu_mohan
Hi team,
is thr any method to calculate it from the ide. or any calculations are there please help.
@kerryzhou
