RT1052的POR引脚的RESET问题
FromCH0
尊敬的NXP:
      RT1052是款性价比很高的主控。很高兴有机会用它来开发产品!
      想请教您们复位方面的问题。贵公司RT1052开发板是通过UM803RS来实现对电压监视和复位的。如果用纽扣电池对VDD_SNVY_IN引脚供电,以实现最低的要求的RTC等运行(日期计算功能)。UM803RS需要接VDD_SNVY_IN引脚供电吗?下图中,POR除了初期下拉之后,后续一直是高电平:上电下电时序.png
如果UM803RS不接VDD_SNVY_IN引脚供电,RESET引脚输出状态未知,是否会影响RTC的正常运行?我上网查了些资料,说UM803RS要接VDD_SNVY_IN引脚供电,而且,RESET引脚需要用VDD_SNVY_IN上拉。
Kan_Li
Hi @FromCH0 ,
复位芯片不需要接VDD_SNVY_IN引脚供电,只有Por_B需要上拉到VDD_SNVY_IN,而且那个上拉电阻可以不贴的,芯片内部有上拉的。详见附件。
Kan
FromCH0
这是NXP的RT1052开发板的原理图(POR相关部分)。
FromCH0
Kan_Li
Hi @FromCH0 ,
Kan
FromCH0
谢了
%3CLINGO-SUB%20id%3D%22lingo-sub-2326034%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERESET%20problem%20with%20the%20POR%20pin%20of%20the%20RT1052%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326034%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20NXP.%3C%2FP%3E%3CP%3E%20%20%20%20%20%20The%20RT1052%20is%20a%20very%20cost-effective%20master%20control.%20I%20am%20glad%20to%20have%20the%20opportunity%20to%20develop%20products%20with%20it!%3C%2FP%3E%3CP%3E%20%20%20%20%20%20I%20would%20like%20to%20ask%20you%20a%20question%20about%20reset.%20Your%20RT1052%20development%20board%20uses%20the%20UM803RS%20for%20voltage%20monitoring%20and%20reset.%20If%20a%20coin%20cell%20battery%20is%20used%20to%20power%20the%20VDD_SNVY_IN%20pin%20in%20order%20to%20achieve%20the%20minimum%20required%20operation%20of%20the%20RTC%2C%20etc.%20(date%20calculation%20function)%2C%20does%20the%20UM803RS%20need%20to%20be%20connected%20to%20the%20VDD_SNVY_IN%20pin%20for%20power%20supply%3F%20In%20the%20diagram%20below%2C%20POR%20is%20subsequently%20always%20high%20except%20after%20the%20initial%20pull-down%3A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E4%B8%8A%E7%94%B5%E4%B8%8B%E7%94%B5%E6%97%B6%E5%BA%8F.png%22%20style%3D%22width%3A%20760px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E4%B8%8A%E7%94%B5%E4%B8%8B%E7%94%B5%E6%97%B6%E5%BA%8F.png%22%20style%3D%22width%3A%20760px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F378305iD1B7F014EF3314F0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E4%B8%8A%E7%94%B5%E4%B8%8B%E7%94%B5%E6%97%B6%E5%BA%8F.png%22%20alt%3D%22%E4%B8%8A%E7%94%B5%E4%B8%8B%E7%94%B5%E6%97%B6%E5%BA%8F.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EIf%20the%20UM803RS%20is%20not%20connected%20to%20the%20VDD_SNVY_IN%20pin%20for%20power%20supply%2C%20and%20the%20output%20state%20of%20the%20RESET%20pin%20is%20unknown%2C%20will%20it%20affect%20the%20normal%20operation%20of%20the%20RTC%3F%20I%20googled%20some%20information%20and%20it%20says%20that%20the%20UM803RS%20has%20to%20be%20connected%20to%20the%20VDD_SNVY_IN%20pin%20for%20power%20supply%2C%20and%2C%20the%20RESET%20pin%20needs%20to%20be%20pulled%20up%20with%20VDD_SNVY_IN.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2326707%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20RT1052%E7%9A%84POR%E5%BC%95%E8%84%9A%E7%9A%84RESET%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326707%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2326701%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20RT1052%E7%9A%84POR%E5%BC%95%E8%84%9A%E7%9A%84RESET%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326701%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F191688%22%20target%3D%22_blank%22%3E%40FromCH0%3C%2FA%3E%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20data-teams%3D%22true%22%3EThe%20reset%20chip%20doesn't%20need%20to%20be%20connected%20to%20the%20VDD_SNVY_IN%20pin%20for%20power%20supply%2C%20only%20Por_B%20needs%20to%20be%20pulled%20up%20to%20VDD_SNVY_IN%2C%20and%20that%20pull-up%20resistor%20can%20be%20left%20unposted%2C%20the%20chip%20has%20an%20internal%20pull-up.%20See%20the%20attachment%20for%20details.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHave%20a%20great%20day%2C%20%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%20%3CBR%20%2F%3ENote%3A%20%3CBR%20%2F%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22%20Mark%20Correct%20%22%20button.%20Thank%20you!%20%3CBR%20%2F%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%20%3CBR%20%2F%3EPlease%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20Please%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%20%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2326037%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20RT1052%E7%9A%84POR%E5%BC%95%E8%84%9A%E7%9A%84RESET%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326037%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22POR%E5%8E%9F%E7%90%86%E5%9B%BE.png%22%20style%3D%22width%3A%200px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22POR%E5%8E%9F%E7%90%86%E5%9B%BE.png%22%20style%3D%22width%3A%200px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F378306iEBFF3C4E3029087D%2Fimage-size%2Fsmall%3Fv%3Dv2%26amp%3Bpx%3D200%22%20width%3D%220%22%20height%3D%220%22%20role%3D%22button%22%20title%3D%22POR%E5%8E%9F%E7%90%86%E5%9B%BE.png%22%20alt%3D%22POR%E5%8E%9F%E7%90%86%E5%9B%BE.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EHere's%20the%20schematic%20for%20NXP's%20RT1052%20development%20board%20(POR%20related%20section).%3C%2FP%3E%3C%2FLINGO-BODY%3E
