RT MQS Example Code
RT MQS Example Code
5,455件の閲覧回数
mhilt
Hi, there seem to be a few posts (see link below), referring to MQS example code, but the links to download it are not working or I do not have access permissions for it.
I am just looking for example code to use MQS on an RT1050. Can you please provide?
There appears to be very little documentation on MQS. Thanks.
https://community.nxp.com/t5/i-MX-RT/Is-there-a-good-example-of-the-use-of-RT105X-MQS/td-p/848513#.Y...
CC:  @Rita_Wang How to use MQS on trial How to use iMXRT1050 MQS? MQS for IMX RT - 1064
ラベル(4)
タグ(2)
5 返答(返信)
5,447件の閲覧回数
kerryzhou
Hi @mhilt ,
    RT MQS is using the SAI3 as the interface, then it can output the medium quality audio. About the document, the RAM MQS chapter 37-39 is a good document.
   About the code, please follow this document:
https://community.nxp.com/t5/HomeTest-Knowledge-Base/How-to-submit-a-new-question-for-NXP-Support/ta...
Create an internal case, and in the case content, write assign to kerry zhou, then I will send you the RT1050 MQS code through the email privately.
Thanks a lot for your understanding.
Kerry
5,316件の閲覧回数
leopoldgemsch
Dear Kerry,
we are also interested to get MQS running on our HW.
It looks there are example codes how to use it.
How can we get access to this examples?
5,303件の閲覧回数
kerryzhou
Hi @leopoldgemsch
Kerry
5,298件の閲覧回数
leopoldgemsch
Dear Kerry,
many thanks for your replay but I only get "Access Denied" message while using your provided link.
(already tried before I wrote my first response).
What do I have to do to access the provided document to follow and create the internal case?
Many thanks for any help
Leopold Gemsch
5,292件の閲覧回数
kerryzhou
Hi @leopoldgemsch
1. Open below SUPPORT site, click blue "Go to Tickets" in the middle.
http://www.nxp.com/support/support:SUPPORTHOME
2.Then you will be requested to Login, if you have no an account, please first Register with your business email.
3.After login, please "Create New Cases" button in the middle, then you can submit your question.
Kerry
