Multiple application firmware
已解决
跳至解决方案
1,869 次查看
LoneWalker
I am working on a solution which allow the firmware update without effecting current mode of operation.
Couple of questions that I have are:
Can ROM bootloader support multiple images e.g. one at address 0x0X and other at address 0x0Y?
Also does it have the facility to boot from a particular address based on some sort flags?
Thanks.
标签 (1)
1 解答
1,864 次查看
jeremyzhou
1) Can the ROM bootloader support multiple images e.g. one at address 0x0X and the other at address 0x0Y?
-- No, I'm afraid not.
2) Also does it have the facility to boot from a particular address based on some sort flags?
-- No.
Regarding your solution, I'd highly recommend you to refer to the application note to make it.
TIC
在原帖中查看解决方案
1 回复
1,865 次查看
jeremyzhou
-- No.
TIC
