MIMXRT1052 eFlexpwm complementary single shot
1,615 次查看
Loadd
I want to output a single shot signal  and its complementary signal with eFlexpwm peripheral. A single shot signal is one pulse which stop counting at next period. Does 1052 support such function?   I know QTIM has one pulse mode. But i need complementary signal as well.
标记 (1)
1,601 次查看
gusarambula
Hello Loadd,
The eFlexPWM module does not have a one-short mode like the QuadTimer. In the case of the eFlexPWM you may generate the complementary signal, but chances are it would be easier setting up the one-shot from the quad timer and generating it’s complementary likewise from the same module.
I hope that this information helps!
Gustavo
1,602 次查看
gusarambula
Hello Loadd,
Gustavo
1,597 次查看
Loadd
Thanks a lot. It's helpful.
