Hello Loadd,
The eFlexPWM module does not have a one-short mode like the QuadTimer. In the case of the eFlexPWM you may generate the complementary signal, but chances are it would be easier setting up the one-shot from the quad timer and generating it’s complementary likewise from the same module.
I hope that this information helps!
Gustavo
Hello Loadd,
Gustavo
