MCIMXRT1170EVK REV C4 can not recognize serial.
811 次查看
takas_2024
Hello.
I have checked the following steps  on my MCIMXRT1170EVK REV C4 board.
Getting Started with the i.MX RT1170 Evaluation Kit | NXP Semiconductors
But, mbedWinSerial driver installer could not find a serial device, and stopped at "Step 2.5 PC Configuration".
Is there any way we can help?
标记 (1)
771 次查看
takas_2024
Hi, Gavin_Jia
Thank you for a nice advice.
I solved my board problem by replacing the USB cable.
The reason why the serial port was not recognized on my PC was the USB cable.
772 次查看
takas_2024
Hi, Gavin_Jia
781 次查看
Gavin_Jia
Hi @takas_2024 ,
Thanks for your interest in NXP MIMXRT series!
At this step 2.5, after installing mbedWinSerial_16466.exe, its expected result should be to see the following in the windows 10 device manager:
After this step, you can flash a HelloWorld project to the board and use the serial port tool such as Tera Term to connect to the board for viewing:
Gavin
