Hart Fault due to the type conversion from unigned long to foat on i.mxrt 1170
817 次查看
ricklei_bakerhughes
I am porting some old code from MPC855T to i.mxrt 1170. The code uses unsigned long for value calculation. Before presenting the value on screen, it's converted to float type and use sprintf to generate the string.
The following is piece of my code:
typedef struct {
unsigned long ulValue;
} typeRegs;
typeRegs * ptrRegs = (typeRegs *)memory address;
float fValue = (float)(ptrRegs->ulValue); // this line will trigger a hart fault error
unsigned long ulTemp = ptrRegs->ulValue;
fValue = (float)ulTemp; // this line works well
I am using Keil, and the ArmClang compiler version is 6.16. I need to understand why I can't convert an unsigned long in point parameter to float directly.
735 次查看
ricklei_bakerhughes
Yes, the exact code works well. But there is a small difference between the code and my implementation. I am not using a memory address directly. I am using an array of unsigned char to allocate the memory space. And this gave me a Hard Fault.
And I figured out the root cause finally. It's due to the alignment error. The conversion from unsigned long to float must be byte aligned. And it seems the array of unsigned char is not aligned with a float value. I changed array defintion to float type. Then it works.
I tried to add "__attribute__ ((aligned(4)))" after the structure defintion. But it didn't work too. I don't know the reason.
Anyway this can be closed.
Thanks!
Rick
789 次查看
Kan_Li
Hi @ricklei_bakerhughes ,
I have pasted your code in some demo like led_blinky , it works well with -O0 optimization option ,  Please kindly refer to the attachment for details.
Kan
736 次查看
ricklei_bakerhughes
Thanks!
Rick
%3CLINGO-SUB%20id%3D%22lingo-sub-2326670%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%94%B1%E4%BA%8E%20i.mxrt%20%E4%B8%8A%E4%BB%8E%E6%97%A0%E7%AC%A6%E5%8F%B7%20long%20%E5%88%B0%20foat%20%E7%9A%84%E7%B1%BB%E5%9E%8B%E8%BD%AC%E6%8D%A2%E5%AF%BC%E8%87%B4%E5%93%88%E7%89%B9%E6%95%85%E9%9A%9C%201170%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326670%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%86%E4%B8%80%E4%BA%9B%E6%97%A7%E4%BB%A3%E7%A0%81%E4%BB%8E%20MPC855T%20%E7%A7%BB%E6%A4%8D%E5%88%B0%20i.mxrt%201170%E3%80%82%E4%BB%A3%E7%A0%81%E4%BD%BF%E7%94%A8%E6%97%A0%E7%AC%A6%E5%8F%B7%20long%20%E8%AE%A1%E7%AE%97%E5%80%BC%E3%80%82%E5%9C%A8%E5%B1%8F%E5%B9%95%E4%B8%8A%E6%98%BE%E7%A4%BA%E6%95%B0%E5%80%BC%E4%B9%8B%E5%89%8D%EF%BC%8C%E5%85%88%E5%B0%86%E5%85%B6%E8%BD%AC%E6%8D%A2%E4%B8%BA%E6%B5%AE%E7%82%B9%E7%B1%BB%E5%9E%8B%EF%BC%8C%E7%84%B6%E5%90%8E%E4%BD%BF%E7%94%A8%20sprintf%20%E7%94%9F%E6%88%90%E5%AD%97%E7%AC%A6%E4%B8%B2%E3%80%82%3CBR%20%2F%3E%E4%B8%8B%E9%9D%A2%E6%98%AF%E6%88%91%E7%9A%84%E4%B8%80%E6%AE%B5%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FP%3E%3CP%3Etypedef%20struct%20%7B%3CBR%20%2F%3Eunsigned%20long%20ULValu%20%3CBR%20%2F%3E%20e%3B%7D%20TypeRegs%3B%20t%20%3CBR%20%2F%3E%20ypeRegs%20*%20ptrRegs%20%3D%20(typeRegs%20*)%20%E5%86%85%E5%AD%98%E5%9C%B0%E5%9D%80%EF%BC%9Bfloat%20fValue%20%3D%20(f%20%3CBR%20%2F%3E%20loat)%20(ptrRegs-%26gt%3B%20ULValue)%3B%2F%2F%E6%AD%A4%E8%A1%8C%E4%BC%9A%E8%A7%A6%E5%8F%91%E5%BF%83%E8%84%8F%E6%95%85%E9%9A%9C%E9%94%99%E8%AF%AF%20%3CBR%20%2F%3E%20unsigned%20long%20%3D%20ptrRegs-%26gt%3B%20ULValue%3B%2F%2F%E6%AD%A4%E8%A1%8C%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20Keil%EF%BC%8CArmClang%20%E7%BC%96%E8%AF%91%E5%99%A8%E7%9A%84%E7%89%88%E6%9C%AC%E6%98%AF%206.16%E3%80%82%E6%88%91%E9%9C%80%E8%A6%81%E4%BA%86%E8%A7%A3%E4%B8%BA%E4%BB%80%E4%B9%88%E4%B8%8D%E8%83%BD%E5%B0%86%E6%97%A0%E7%AC%A6%E5%8F%B7%20long%20in%20point%20%E5%8F%82%E6%95%B0%E7%9B%B4%E6%8E%A5%E8%BD%AC%E6%8D%A2%E4%B8%BA%20float%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2326799%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Hart%20Fault%20due%20to%20the%20type%20conversion%20from%20unigned%20long%20to%20foat%20on%20i.mxrt%201170%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326799%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E6%98%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246904%22%20target%3D%22_blank%22%3E%40ricklei_bakerhughes%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E5%B7%B2%E5%B0%86%E6%82%A8%E7%9A%84%E4%BB%A3%E7%A0%81%E7%B2%98%E8%B4%B4%E5%88%B0%20led_blinky%20%E7%AD%89%E6%BC%94%E7%A4%BA%E7%A8%8B%E5%BA%8F%E4%B8%AD%EF%BC%8C%E5%9C%A8%E4%BD%BF%E7%94%A8%20-O0%20%E4%BC%98%E5%8C%96%E9%80%89%E9%A1%B9%E6%97%B6%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%EF%BC%8C%E8%AF%A6%E6%83%85%E8%AF%B7%E5%8F%82%E8%A7%81%E9%99%84%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%89%93%E5%BC%80%E4%B8%80%E4%B8%AA%E6%96%B0%E4%B8%BB%E9%A2%98%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2328162%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Hart%20Fault%20due%20to%20the%20type%20conversion%20from%20unigned%20long%20to%20foat%20on%20i.mxrt%201170%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2328162%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E7%A1%AE%E5%88%87%E7%9A%84%E4%BB%A3%E7%A0%81%E6%95%88%E6%9E%9C%E5%BE%88%E5%A5%BD%E3%80%82%E4%BD%86%E4%BB%A3%E7%A0%81%E5%92%8C%E6%88%91%E7%9A%84%E5%AE%9E%E7%8E%B0%E4%B9%8B%E9%97%B4%E6%9C%89%E4%B8%80%E7%82%B9%E4%B8%8D%E5%90%8C%E3%80%82%E6%88%91%E6%B2%A1%E6%9C%89%E7%9B%B4%E6%8E%A5%E4%BD%BF%E7%94%A8%E5%86%85%E5%AD%98%E5%9C%B0%E5%9D%80%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E4%B8%80%E4%B8%AA%E6%97%A0%E7%AC%A6%E5%8F%B7%20char%20%E6%95%B0%E7%BB%84%E6%9D%A5%E5%88%86%E9%85%8D%E5%86%85%E5%AD%98%E7%A9%BA%E9%97%B4%E3%80%82%E8%BF%99%E7%BB%99%E4%BA%86%E6%88%91%E4%B8%80%E4%B8%AA%20%22%E7%A1%AC%E6%95%85%E9%9A%9C%22%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%88%91%E7%BB%88%E4%BA%8E%E6%89%BE%E5%88%B0%E4%BA%86%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E3%80%82%E8%BF%99%E6%98%AF%E7%94%B1%E4%BA%8E%E5%AF%B9%E9%BD%90%E8%AF%AF%E5%B7%AE%E9%80%A0%E6%88%90%E7%9A%84%E3%80%82%E4%BB%8E%E6%97%A0%E7%AC%A6%E5%8F%B7%E9%95%BF%E6%95%B4%E6%95%B0%E8%BD%AC%E6%8D%A2%E4%B8%BA%E6%B5%AE%E7%82%B9%E6%95%B0%E5%BF%85%E9%A1%BB%E6%98%AF%E5%AD%97%E8%8A%82%E5%AF%B9%E9%BD%90%E7%9A%84%E3%80%82%E6%97%A0%E7%AC%A6%E5%8F%B7%E5%AD%97%E7%AC%A6%E6%95%B0%E7%BB%84%E4%BC%BC%E4%B9%8E%E6%B2%A1%E6%9C%89%E4%B8%8E%E6%B5%AE%E7%82%B9%E6%95%B0%E5%80%BC%E5%AF%B9%E9%BD%90%E3%80%82%E6%88%91%E5%B0%86%E6%95%B0%E7%BB%84%E5%AE%9A%E4%B9%89%E6%94%B9%E4%B8%BA%E6%B5%AE%E7%82%B9%E7%B1%BB%E5%9E%8B%E3%80%82%E7%84%B6%E5%90%8E%E5%AE%83%E5%B0%B1%E8%83%BD%E5%B7%A5%E4%BD%9C%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E5%9C%A8%E7%BB%93%E6%9E%84%E5%AE%9A%E4%B9%89%E5%90%8E%E6%B7%BB%E5%8A%A0%22__attribute__%20((aligned(4))%22%20%E3%80%82%E4%BD%86%E4%B9%9F%E6%B2%A1%E6%9C%89%E5%A5%8F%E6%95%88%E3%80%82%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E5%8E%9F%E5%9B%A0%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%80%BB%E4%B9%8B%EF%BC%8C%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%8F%AF%E4%BB%A5%E4%BA%86%E7%BB%93%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%EF%BC%81%3C%2FP%3E%3CP%3E%E9%87%8C%E5%85%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E
