CAAM endianess for computed CRC
504件の閲覧回数
mastupristi
Senior Contributor I
Using the CAAM example from SDK 25.06.00 as a starting point, I created the attached project.
In this test, I have an array of 16 elements containing the numbers 0 through 15, and I calculate the CRC for progressively larger portions of this array using two different CRC algorithms.
I calculate the first 16 values using these CRC parameters:
  • Poly = 0x1edc6f41
  • XorIn = 0xffffffff
  • ReflectIn = True
  • XorOut = 0xffffffff
  • ReflectOut = True
This means that the mode is kCAAM_CRC_ModeDefault.
These are the expected CRC values and the actual CRC values:
num elements in the arrayexpected crccomputed crc
10x527d5351527d5351
20x30af4d130af4d1
30x92fd4bfa92fd4bfa
40xd9331aa3d9331aa3
50x2425b1062425b106
60x4109851441098514
70xa359ed4ca359ed4c
80x8a2cbc3b8a2cbc3b
90x7144c5a87144c5a8
100x22c213122c2131
110xfb159dfafb159dfa
120x5383aaba5383aaba
130xc69a45dac69a45da
140x55a24c5455a24c54
150x68ef03f668ef03f6
160xd9c908ebd9c908eb
They all match, and I believe they would do so for any input I might provide. From this, we can conclude that the CRC calculated by CAAM is stored in memory in little-endian format.
Now let's make just a small change to the algorithm:
  • Poly = 0x1edc6f41
  • ReflectIn = True
  • ReflectOut = False
This means that the mode is kCAAM_CRC_ModeDOS, the DOS bit is 1.
Let's check the results
10x8acabe4a4abeca8a
20x8b2f50c0c0502f8b
30x5fd2bf4949bfd25f
40xc558cc9b9bcc58c5
50x608da42424a48d60
60x28a190828290a128
70x32b79ac5c59ab732
80xdc3d345151343ddc
90x15a3228e8e22a315
100x8c8434404034848c
110x5fb9a8dfdfa8b95f
120x5d55c1cacac1555d
130x5ba259636359a25b
140x2a3245aaaa45322a
150x6fc0f71616f7c06f
160xd710939b9b9310d7
The endianess is different. It's as if, in this case, they were saved in big-endian format.
All it took was the DOS bit, which is described in two different ways in the manual
At one point, DOS is described as bit-swap, while shortly thereafter it is described as bit/byte swap.
The question is: How can I ensure that the calculation is consistent regardless of the DOS bit and, above all, consistent with the expected value?
In the project you will find the bash script test.sh to compute crc a get the expected values.
best regards
Max 
タグ(2)
3 返答(返信)
465件の閲覧回数
Kan_Li
 Hi @mastupristi ,
The description for DOS in Table 6-212 is correct, then it is enabled, the output value is bit- and byte-swapping. It can also be interpreted from your results, For example , when DOS is not enabled, the CRC is 0x527d5351, when DOS is enabled, the result would be 0x8acabe4a if it just enables bit-swapping, while it is bit- and byte-swapping, so the result is 0x4abeca8a.
Hope that makes sense,
Kan
459件の閲覧回数
mastupristi
Hi @Kan_Li
You didn't answer the question:
regards
Max
426件の閲覧回数
Kan_Li
Hi @mastupristi ,
As I mentioned before, referring to Table 6-212, for the output, the bit swapping and byte swapping options are enabled/disabled together, so there isn't a way to do one, but not the other. so it is not possible to have an output with only bit swapping is enabled.
Kan
%3CLINGO-SUB%20id%3D%22lingo-sub-2337053%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%9FCRC%E3%81%AECAAM%E3%82%A8%E3%83%B3%E3%83%87%E3%82%A3%E3%82%A2%E3%83%B3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2337053%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3ESDK%2025.06.00%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8BCAAM%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%E5%8F%82%E8%80%83%E3%81%AB%E3%80%81%E6%B7%BB%E4%BB%98%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%81%AF%E3%80%810%E3%81%8B%E3%82%8915%E3%81%BE%E3%81%A7%E3%81%AE%E6%95%B0%E5%AD%97%E3%82%92%E5%90%AB%E3%82%8016%E5%80%8B%E3%81%AE%E8%A6%81%E7%B4%A0%E3%81%8B%E3%82%89%E3%81%AA%E3%82%8B%E9%85%8D%E5%88%97%E3%82%92%E7%94%A8%E6%84%8F%E3%81%97%E3%80%812%E3%81%A4%E3%81%AE%E7%95%B0%E3%81%AA%E3%82%8BCRC%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%81%93%E3%81%AE%E9%85%8D%E5%88%97%E3%81%AE%E3%82%88%E3%82%8A%E5%A4%A7%E3%81%8D%E3%81%AA%E9%83%A8%E5%88%86%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6CRC%E3%82%92%E8%A8%88%E7%AE%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AECRC%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AE16%E5%80%8B%E3%81%AE%E5%80%A4%E3%82%92%E8%A8%88%E7%AE%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%E3%83%9D%E3%83%AA%20%3D%200x1edc6f41%3C%2FLI%3E%3CLI%3EXorIn%20%3D%200xffffffff%3C%2FLI%3E%3CLI%3EReflectIn%20%3D%20True%3C%2FLI%3E%3CLI%3EXorOut%20%3D%200xffffffff%3C%2FLI%3E%3CLI%3EReflectOut%20%3D%20True%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%3CSPAN%3EkCAAM_CRC_ModeDefault%3C%2FSPAN%3E%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%80%81%E4%BA%88%E6%83%B3%E3%81%95%E3%82%8C%E3%82%8BCRC%E5%80%A4%E3%81%A8%E5%AE%9F%E9%9A%9B%E3%81%AECRC%E5%80%A4%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E%3CSTRONG%3E%E9%85%8D%E5%88%97%E5%86%85%E3%81%AE%E8%A6%81%E7%B4%A0%E6%95%B0%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E%3CSTRONG%3E%E6%9C%9F%E5%BE%85%E3%81%95%E3%82%8C%E3%82%8BCRC%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E%3CSTRONG%3E%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%9FCRC%3C%2FSTRONG%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E1%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E0x527d5351%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E527d5351%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E2%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E0x30af4d1%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E30af4d1%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E3%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E0x92fd4bfa%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E92fd4bfa%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E4%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E0xd9331aa3%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3Ed9331aa3%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E5%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E0x2425b106%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E2425b106%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E6%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E0x41098514%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E41098514%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E7%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E0xa359ed4c%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3Ea359ed4c%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20height%3D%2224px%22%3E8%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E0x8a2cbc3b%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E8a2cbc3b%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20height%3D%2224px%22%3E9%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E0x7144c5a8%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E7144c5a8%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20height%3D%2224px%22%3E10%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E0x22c2131%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E22c2131%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20height%3D%2224px%22%3E11%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E0xfb159dfa%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3Efb159dfa%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20height%3D%2224px%22%3E12%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E0x5383aaba%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E5383aaba%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20height%3D%2224px%22%3E13%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E0xc69a45da%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3Ec69a45da%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20height%3D%2224px%22%3E14%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E0x55a24c54%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E55a24c54%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20height%3D%2224px%22%3E15%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E0x68ef03f6%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E68ef03f6%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20height%3D%2224px%22%3E16%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E0xd9c908eb%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3Ed9c908eb%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CBR%20%2F%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E7%A7%81%E3%81%8C%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E6%84%8F%E8%A6%8B%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%82%82%E3%80%81%E5%BD%BC%E3%82%89%E3%81%AF%E5%90%8C%E6%A7%98%E3%81%AB%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%8F%E3%82%8C%E3%82%8B%E3%81%A8%E7%A7%81%E3%81%AF%E4%BF%A1%E3%81%98%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%81%93%E3%81%A8%E3%81%8B%E3%82%89%E3%80%81CAAM%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%9FCRC%E3%81%AF%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AB%E3%83%AA%E3%83%88%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%87%E3%82%A3%E3%82%A2%E3%83%B3%E5%BD%A2%E5%BC%8F%E3%81%A7%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A8%E7%B5%90%E8%AB%96%E3%81%A5%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%A7%E3%81%AF%E3%80%81%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%AB%E3%81%BB%E3%82%93%E3%81%AE%E5%B0%91%E3%81%97%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E3%83%9D%E3%83%AA%20%3D%200x1edc6f41%3C%2FLI%3E%3CLI%3EXorIn%20%3D%200xffffffff%3C%2FLI%3E%3CLI%3EReflectIn%20%3D%20True%3C%2FLI%3E%3CLI%3EXorOut%20%3D%200xffffffff%3C%2FLI%3E%3CLI%3E%3CFONT%20color%3D%22%23800000%22%3E%3CSTRONG%3EReflectOut%20%3D%20False%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%3CSTRONG%3EkCAAM_CRC_ModeDOS%3C%2FSTRONG%3E%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81DOS%E3%83%93%E3%83%83%E3%83%88%E3%81%8C1%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%B5%90%E6%9E%9C%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%82%87%E3%81%86%3C%2FP%3E%3CTABLE%20border%3D%221%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E%3CSTRONG%3E%E9%85%8D%E5%88%97%E5%86%85%E3%81%AE%E8%A6%81%E7%B4%A0%E6%95%B0%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E%3CSTRONG%3E%E6%9C%9F%E5%BE%85%E3%81%95%E3%82%8C%E3%82%8BCRC%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3E%3CSTRONG%3E%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%9FCRC%3C%2FSTRONG%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E1%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x8acabe4a%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3E4abeca8a%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E2%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x8b2f50c0%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3Ec0502f8b%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E3%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x5fd2bf49%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3E49bfd25f%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E4%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0xc558cc9b%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3E9bcc58c5%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E5%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x608da424%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3E24a48d60%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E6%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x28a19082%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3E8290a128%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E7%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x32b79ac5%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3Ec59ab732%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E8%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0xdc3d3451%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3E51343ddc%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E9%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x15a3228e%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3E8e22a315%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E10%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x8c843440%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3E4034848c%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E11%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x5fb9a8df%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3Edfa8b95f%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E12%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x5d55c1ca%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3Ecac1555d%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E13%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x5ba25963%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3E6359a25b%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E14%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x2a3245aa%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3Eaa45322a%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E15%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x6fc0f716%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3E16f7c06f%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E16%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0xd710939b%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3E9b9310d7%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CBR%20%2F%3E%3CP%3E%E3%82%A8%E3%83%B3%E3%83%87%E3%82%A3%E3%82%A2%E3%83%B3%E3%81%8C%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%81%BE%E3%82%8B%E3%81%A7%E3%83%93%E3%83%83%E3%82%B0%E3%82%A8%E3%83%B3%E3%83%87%E3%82%A3%E3%82%A2%E3%83%B3%E5%BD%A2%E5%BC%8F%E3%81%A7%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%9F%E3%81%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%A0%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%AE%E3%81%AFDOS%E3%83%93%E3%83%83%E3%83%88%E3%81%A0%E3%81%91%E3%81%A7%E3%80%81%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E3%81%AF2%E3%81%A4%E3%81%AE%E7%95%B0%E3%81%AA%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%A7%E8%AA%AC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%80%82%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot_2026-03-21_22-47-23.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot_2026-03-21_22-47-23.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot_2026-03-21_22-47-23.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot_2026-03-21_22-47-23.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot_2026-03-21_22-47-23.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F379987iF514231E601C632E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot_2026-03-21_22-47-23.png%22%20alt%3D%22Screenshot_2026-03-21_22-47-23.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8B%E6%99%82%E7%82%B9%E3%81%A7%E3%81%AF%E3%80%81DOS%E3%81%AF%E3%83%93%E3%83%83%E3%83%88%E3%82%B9%E3%83%AF%E3%83%83%E3%83%97%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E8%AA%AC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E7%9B%B4%E5%BE%8C%E3%81%AB%E3%81%AF%E3%83%93%E3%83%83%E3%83%88%2F%E3%83%90%E3%82%A4%E3%83%88%E3%82%B9%E3%83%AF%E3%83%83%E3%83%97%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E8%AA%AC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81DOS%E3%83%93%E3%83%83%E3%83%88%E3%81%AB%E9%96%A2%E4%BF%82%E3%81%AA%E3%81%8F%E8%A8%88%E7%AE%97%E7%B5%90%E6%9E%9C%E3%81%8C%E4%B8%80%E8%B2%AB%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E4%BD%95%E3%82%88%E3%82%8A%E3%82%82%E6%9C%9F%E5%BE%85%E5%80%A4%E3%81%A8%E4%B8%80%E8%B2%AB%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E4%BF%9D%E8%A8%BC%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E3%81%AF%E3%80%81CRC%E3%82%92%E8%A8%88%E7%AE%97%E3%81%97%E3%81%A6%E6%9C%9F%E5%BE%85%E5%80%A4%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AEbash%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88test.sh%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%9E%E3%83%83%E3%82%AF%E3%82%B9%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2337380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20endianess%20for%20computed%20CRC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2337380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E8%B3%AA%E5%95%8F%E3%81%AB%E7%AD%94%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot_2026-03-23_08-53-39.png%22%20style%3D%22width%3A%20725px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot_2026-03-23_08-53-39.png%22%20style%3D%22width%3A%20725px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot_2026-03-23_08-53-39.png%22%20style%3D%22width%3A%20725px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot_2026-03-23_08-53-39.png%22%20style%3D%22width%3A%20725px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F380054iF1C4089A042C16D2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot_2026-03-23_08-53-39.png%22%20alt%3D%22Screenshot_2026-03-23_08-53-39.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%80%E5%A4%A7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2337328%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20endianess%20for%20computed%20CRC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2337328%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F124967%22%20target%3D%22_blank%22%3E%40mastupristi%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%A1%A86-212%E3%81%AEDOS%E3%81%AE%E8%AA%AC%E6%98%8E%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%8F%E3%80%81%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E5%87%BA%E5%8A%9B%E5%80%A4%E3%81%AF%E3%83%93%E3%83%83%E3%83%88%E3%81%8A%E3%82%88%E3%81%B3%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E3%82%B9%E3%83%AF%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E7%B5%90%E6%9E%9C%E3%81%8B%E3%82%89%E8%A7%A3%E9%87%88%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81DOS%20%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81CRC%20%E3%81%AF%200x%20%3CSPAN%3E527d5351%20%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81DOS%20%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%83%93%E3%83%83%E3%83%88%20%E3%82%B9%E3%83%AF%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%AE%E3%81%BF%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E7%B5%90%E6%9E%9C%E3%81%AF%200x8acabe4a%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%93%E3%83%83%E3%83%88%E3%81%A8%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E3%82%B9%E3%83%AF%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E7%B5%90%E6%9E%9C%E3%81%AF%200x4abeca8a%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%8C%E3%81%A7%E6%84%8F%E5%91%B3%E3%81%8C%E9%80%9A%E3%81%98%E3%82%8B%E3%81%A8%E3%81%84%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%82%AB%E3%83%B3%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%EF%BC%9A%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20-%20%E6%9C%80%E5%BE%8C%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%897%E9%80%B1%E9%96%93%E3%81%AFThread%E3%82%92%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%BE%8C%E6%97%A5%E3%80%81%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84Thread%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E9%96%89%E3%81%98%E3%82%89%E3%82%8C%E3%81%9FThread%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2338206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20endianess%20for%20computed%20CRC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2338206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F124967%22%20target%3D%22_blank%22%3E%40mastupristi%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%85%88%E3%81%BB%E3%81%A9%E8%A1%A86-212%E3%81%A7%E8%BF%B0%E3%81%B9%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E5%87%BA%E5%8A%9B%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81%E3%83%93%E3%83%83%E3%83%88%E3%82%B9%E3%83%AF%E3%83%83%E3%83%97%E3%81%A8%E3%83%90%E3%82%A4%E3%83%88%E3%82%B9%E3%83%AF%E3%83%83%E3%83%97%E3%81%AE%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E5%90%8C%E6%99%82%E3%81%AB%E6%9C%89%E5%8A%B9%2F%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%A9%E3%81%A1%E3%82%89%E3%81%8B%E4%B8%80%E6%96%B9%E3%81%A0%E3%81%91%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%82%82%E3%81%86%E4%B8%80%E6%96%B9%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%83%93%E3%83%83%E3%83%88%E3%82%B9%E3%83%AF%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%AE%E3%81%BF%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E7%8A%B6%E6%85%8B%E3%81%A7%E3%81%AF%E5%87%BA%E5%8A%9B%E3%82%92%E5%BE%97%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%82%AB%E3%83%B3%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%EF%BC%9A%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20-%20%E6%9C%80%E5%BE%8C%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%897%E9%80%B1%E9%96%93%E3%81%AFThread%E3%82%92%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%BE%8C%E6%97%A5%E3%80%81%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84Thread%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E9%96%89%E3%81%98%E3%82%89%E3%82%8C%E3%81%9FThread%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
