CAAM endianess for computed CRC
508 次查看
mastupristi
Senior Contributor I
Using the CAAM example from SDK 25.06.00 as a starting point, I created the attached project.
In this test, I have an array of 16 elements containing the numbers 0 through 15, and I calculate the CRC for progressively larger portions of this array using two different CRC algorithms.
I calculate the first 16 values using these CRC parameters:
  • Poly = 0x1edc6f41
  • XorIn = 0xffffffff
  • ReflectIn = True
  • XorOut = 0xffffffff
  • ReflectOut = True
This means that the mode is kCAAM_CRC_ModeDefault.
These are the expected CRC values and the actual CRC values:
num elements in the arrayexpected crccomputed crc
10x527d5351527d5351
20x30af4d130af4d1
30x92fd4bfa92fd4bfa
40xd9331aa3d9331aa3
50x2425b1062425b106
60x4109851441098514
70xa359ed4ca359ed4c
80x8a2cbc3b8a2cbc3b
90x7144c5a87144c5a8
100x22c213122c2131
110xfb159dfafb159dfa
120x5383aaba5383aaba
130xc69a45dac69a45da
140x55a24c5455a24c54
150x68ef03f668ef03f6
160xd9c908ebd9c908eb
They all match, and I believe they would do so for any input I might provide. From this, we can conclude that the CRC calculated by CAAM is stored in memory in little-endian format.
Now let's make just a small change to the algorithm:
  • Poly = 0x1edc6f41
  • ReflectIn = True
  • ReflectOut = False
This means that the mode is kCAAM_CRC_ModeDOS, the DOS bit is 1.
Let's check the results
10x8acabe4a4abeca8a
20x8b2f50c0c0502f8b
30x5fd2bf4949bfd25f
40xc558cc9b9bcc58c5
50x608da42424a48d60
60x28a190828290a128
70x32b79ac5c59ab732
80xdc3d345151343ddc
90x15a3228e8e22a315
100x8c8434404034848c
110x5fb9a8dfdfa8b95f
120x5d55c1cacac1555d
130x5ba259636359a25b
140x2a3245aaaa45322a
150x6fc0f71616f7c06f
160xd710939b9b9310d7
The endianess is different. It's as if, in this case, they were saved in big-endian format.
All it took was the DOS bit, which is described in two different ways in the manual
At one point, DOS is described as bit-swap, while shortly thereafter it is described as bit/byte swap.
The question is: How can I ensure that the calculation is consistent regardless of the DOS bit and, above all, consistent with the expected value?
In the project you will find the bash script test.sh to compute crc a get the expected values.
best regards
Max 
标记 (2)
469 次查看
Kan_Li
 Hi @mastupristi ,
The description for DOS in Table 6-212 is correct, then it is enabled, the output value is bit- and byte-swapping. It can also be interpreted from your results, For example , when DOS is not enabled, the CRC is 0x527d5351, when DOS is enabled, the result would be 0x8acabe4a if it just enables bit-swapping, while it is bit- and byte-swapping, so the result is 0x4abeca8a.
Hope that makes sense,
Kan
463 次查看
mastupristi
Hi @Kan_Li
You didn't answer the question:
regards
Max
430 次查看
Kan_Li
Hi @mastupristi ,
As I mentioned before, referring to Table 6-212, for the output, the bit swapping and byte swapping options are enabled/disabled together, so there isn't a way to do one, but not the other. so it is not possible to have an output with only bit swapping is enabled.
Kan
%3CLINGO-SUB%20id%3D%22lingo-sub-2337053%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%AE%A1%E7%AE%97%20CRC%20%E7%9A%84%20CAAM%20%E7%AB%AF%E4%BD%8D%E6%95%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2337053%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%E4%BB%A5%20SDK%2025.06.00%20%E4%B8%AD%E7%9A%84%20CAAM%20%E7%A4%BA%E4%BE%8B%E4%B8%BA%E8%B5%B7%E7%82%B9%EF%BC%8C%E6%88%91%E5%88%9B%E5%BB%BA%E4%BA%86%E6%89%80%E9%99%84%E9%A1%B9%E7%9B%AE%E3%80%82%3CBR%20%2F%3E%E5%9C%A8%E8%BF%99%E4%B8%AA%E6%B5%8B%E8%AF%95%E4%B8%AD%EF%BC%8C%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E5%8C%85%E5%90%AB%200%20%E5%88%B0%2015%20%E4%B8%AA%E6%95%B0%E5%AD%97%E7%9A%84%2016%20%E4%B8%AA%E5%85%83%E7%B4%A0%E7%9A%84%E6%95%B0%E7%BB%84%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E4%B8%A4%E7%A7%8D%E4%B8%8D%E5%90%8C%E7%9A%84%20CRC%20%E7%AE%97%E6%B3%95%E8%AE%A1%E7%AE%97%E8%BF%99%E4%B8%AA%E6%95%B0%E7%BB%84%E4%B8%AD%E9%80%90%E6%B8%90%E5%A2%9E%E5%A4%A7%E7%9A%84%E9%83%A8%E5%88%86%E7%9A%84%20CRC%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E8%BF%99%E4%BA%9B%20CRC%20%E5%8F%82%E6%95%B0%E8%AE%A1%E7%AE%97%E5%89%8D%2016%20%E4%B8%AA%E5%80%BC%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3EPoly%20%3D%200x1edc6f41%3C%2FLI%3E%3CLI%3EXorIn%20%3D%200xffffffff%3C%2FLI%3E%3CLI%3EReflectIn%20%3D%20True%3C%2FLI%3E%3CLI%3EXorOut%20%3D%200xffffffff%3C%2FLI%3E%3CLI%3EReflectOut%20%3D%20True%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E6%A8%A1%E5%BC%8F%E4%B8%BA%3CSPAN%3EkCAAM_CRC_ModeDefault%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E8%BF%99%E5%B0%B1%E6%98%AF%E9%A2%84%E6%9C%9F%E7%9A%84%20CRC%20%E5%80%BC%E5%92%8C%E5%AE%9E%E9%99%85%E7%9A%84%20CRC%20%E5%80%BC%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E%3CSTRONG%3E%E6%95%B0%E7%BB%84%E4%B8%AD%E7%9A%84%E5%85%83%E7%B4%A0%E4%B8%AA%E6%95%B0%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E%3CSTRONG%3E%E9%A2%84%E6%9C%9F%20crc%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E%3CSTRONG%3E%E8%AE%A1%E7%AE%97%E7%9A%84%20cc%3C%2FSTRONG%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E1%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E0x527d5351%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E527d5351%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E2%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E0x30af4d1%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E30af4d1%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E3%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E0x92fd4bfa%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E92fd4bfa%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E4%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E0xd9331aa3%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3Ed9331aa3%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E5%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E0x2425b106%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E2425b106%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E6%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E0x41098514%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E41098514%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E7%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3E0xa359ed4c%3C%2FTD%3E%3CTD%20width%3D%2233.333333333333336%25%22%20height%3D%2224px%22%3Ea359ed4c%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20height%3D%2224px%22%3E8%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E0x8a2cbc3b%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E8a2cbc3b%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20height%3D%2224px%22%3E9%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E0x7144c5a8%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E7144c5a8%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20height%3D%2224px%22%3E10%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E0x22c2131%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E22c2131%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20height%3D%2224px%22%3E11%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E0xfb159dfa%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3Efb159dfa%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20height%3D%2224px%22%3E12%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E0x5383aaba%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E5383aaba%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20height%3D%2224px%22%3E13%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E0xc69a45da%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3Ec69a45da%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20height%3D%2224px%22%3E14%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E0x55a24c54%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E55a24c54%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20height%3D%2224px%22%3E15%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E0x68ef03f6%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E68ef03f6%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20height%3D%2224px%22%3E16%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3E0xd9c908eb%3C%2FTD%3E%3CTD%20height%3D%2224px%22%3Ed9c908eb%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CBR%20%2F%3E%3CP%3E%E4%BB%96%E4%BB%AC%E9%83%BD%E5%BE%88%E9%85%8D%E5%90%88%EF%BC%8C%E8%80%8C%E4%B8%94%E6%88%91%E7%9B%B8%E4%BF%A1%EF%BC%8C%E5%8F%AA%E8%A6%81%E6%88%91%E6%8F%90%E4%BE%9B%E4%BB%BB%E4%BD%95%E6%84%8F%E8%A7%81%EF%BC%8C%E4%BB%96%E4%BB%AC%E9%83%BD%E4%BC%9A%E8%BF%99%E4%B9%88%E5%81%9A%E3%80%82%E7%94%B1%E6%AD%A4%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E5%BE%97%E5%87%BA%E7%BB%93%E8%AE%BA%EF%BC%8CCAAM%20%E8%AE%A1%E7%AE%97%E7%9A%84%20CRC%20%E6%98%AF%E4%BB%A5%E5%B0%8F%E5%8F%8C%E4%BD%8D%E6%A0%BC%E5%BC%8F%E5%AD%98%E5%82%A8%E5%9C%A8%E5%86%85%E5%AD%98%E4%B8%AD%E7%9A%84%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%8E%B0%E5%9C%A8%EF%BC%8C%E8%AE%A9%E6%88%91%E4%BB%AC%E5%AF%B9%E7%AE%97%E6%B3%95%E7%A8%8D%E4%BD%9C%E4%BF%AE%E6%94%B9%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CUL%3E%3CLI%3EPoly%20%3D%200x1edc6f41%3C%2FLI%3E%3CLI%3EXorIn%20%3D%200xffffffff%3C%2FLI%3E%3CLI%3EReflectIn%20%3D%20True%3C%2FLI%3E%3CLI%3EXorOut%20%3D%200xffffffff%3C%2FLI%3E%3CLI%3E%3CFONT%20color%3D%22%23800000%22%3E%3CSTRONG%3E%E5%8F%8D%E5%B0%84%E8%BE%93%E5%87%BA%20%3D%20%E5%81%87%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E6%A8%A1%E5%BC%8F%E4%B8%BA%3CSTRONG%3EkCAAM_CRC_ModeDOS%3C%2FSTRONG%3E%EF%BC%8CDOS%20%E4%BD%8D%E4%B8%BA%201%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%AE%A9%E6%88%91%E4%BB%AC%E6%A3%80%E6%9F%A5%E7%BB%93%E6%9E%9C%3C%2FP%3E%3CTABLE%20border%3D%221%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E%3CSTRONG%3E%E6%95%B0%E7%BB%84%E4%B8%AD%E7%9A%84%E5%85%83%E7%B4%A0%E4%B8%AA%E6%95%B0%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E%3CSTRONG%3E%E9%A2%84%E6%9C%9F%20crc%3C%2FSTRONG%3E%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3E%3CSTRONG%3E%E8%AE%A1%E7%AE%97%E7%9A%84%20cc%3C%2FSTRONG%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E1%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x8acabe4a%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3E4abeca8a%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E2%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x8b2f50c0%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3Ec0502f8b%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E3%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x5fd2bf49%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3E49bfd25f%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E4%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0xc558cc9b%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3E9bcc58c5%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E5%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x608da424%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3E24a48d60%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E6%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x28a19082%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3E8290a128%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E7%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x32b79ac5%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3Ec59ab732%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E8%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0xdc3d3451%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3E51343ddc%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E9%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x15a3228e%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3E8e22a315%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E10%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x8c843440%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3E4034848c%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E11%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x5fb9a8df%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3Edfa8b95f%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E12%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x5d55c1ca%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3Ecac1555d%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E13%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x5ba25963%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3E6359a25b%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E14%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x2a3245aa%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3Eaa45322a%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E15%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0x6fc0f716%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3E16f7c06f%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20width%3D%22226.3px%22%20height%3D%2224px%22%3E16%3C%2FTD%3E%3CTD%20width%3D%22226.317px%22%20height%3D%2224px%22%3E0xd710939b%3C%2FTD%3E%3CTD%20width%3D%22226.283px%22%20height%3D%2224px%22%3E9b9310d7%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CBR%20%2F%3E%3CP%3E%E5%86%85%E7%A0%81%E4%B8%8D%E5%90%8C%E3%80%82%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E5%B0%B1%E5%A5%BD%E5%83%8F%E5%AE%83%E4%BB%AC%E6%98%AF%E4%BB%A5%E5%A4%A7%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%A0%BC%E5%BC%8F%E4%BF%9D%E5%AD%98%E7%9A%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%8F%AA%E9%9C%80%20DOS%20%E4%BD%8D%EF%BC%8C%E6%89%8B%E5%86%8C%E4%B8%AD%E5%AF%B9%E6%AD%A4%E6%9C%89%E4%B8%A4%E7%A7%8D%E4%B8%8D%E5%90%8C%E7%9A%84%E6%8F%8F%E8%BF%B0%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot_2026-03-21_22-47-23.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot_2026-03-21_22-47-23.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot_2026-03-21_22-47-23.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot_2026-03-21_22-47-23.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot_2026-03-21_22-47-23.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F379987iF514231E601C632E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot_2026-03-21_22-47-23.png%22%20alt%3D%22Screenshot_2026-03-21_22-47-23.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%9C%89%E4%B8%80%E6%AC%A1%EF%BC%8CDOS%20%E8%A2%AB%E6%8F%8F%E8%BF%B0%E4%B8%BA%E4%BD%8D%E4%BA%A4%E6%8D%A2%EF%BC%8C%E4%B8%8D%E4%B9%85%E4%B9%8B%E5%90%8E%E5%AE%83%E8%A2%AB%E6%8F%8F%E8%BF%B0%E4%B8%BA%E4%BD%8D%2F%E5%AD%97%E8%8A%82%E4%BA%A4%E6%8D%A2%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%9A%E5%A6%82%E4%BD%95%E7%A1%AE%E4%BF%9D%E8%AE%A1%E7%AE%97%E7%BB%93%E6%9E%9C%E4%B8%8E%20DOS%20%E4%BD%8D%E4%B8%80%E8%87%B4%EF%BC%8C%E5%B0%A4%E5%85%B6%E6%98%AF%E4%B8%8E%E9%A2%84%E6%9C%9F%E5%80%BC%E4%B8%80%E8%87%B4%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%9C%A8%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%E7%94%A8%E4%BA%8E%E8%AE%A1%E7%AE%97%20crc%20%E5%92%8C%E8%8E%B7%E5%8F%96%E9%A2%84%E6%9C%9F%E5%80%BC%E7%9A%84%20bash%20%E8%84%9A%E6%9C%AC%20test.sh%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E9%97%AE%E5%80%99%3C%2FP%3E%3CP%3E%E6%9C%80%E5%A4%A7%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2337380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20endianess%20for%20computed%20CRC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2337380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%3C%2FP%3E%3CP%3E%E4%BD%A0%E6%B2%A1%E6%9C%89%E5%9B%9E%E7%AD%94%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot_2026-03-23_08-53-39.png%22%20style%3D%22width%3A%20725px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot_2026-03-23_08-53-39.png%22%20style%3D%22width%3A%20725px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot_2026-03-23_08-53-39.png%22%20style%3D%22width%3A%20725px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot_2026-03-23_08-53-39.png%22%20style%3D%22width%3A%20725px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F380054iF1C4089A042C16D2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot_2026-03-23_08-53-39.png%22%20alt%3D%22Screenshot_2026-03-23_08-53-39.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E9%97%AE%E5%80%99%3C%2FP%3E%3CP%3E%E6%9C%80%E5%A4%A7%E5%80%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2337328%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20endianess%20for%20computed%20CRC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2337328%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F124967%22%20target%3D%22_blank%22%3E%40mastupristi%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%A1%A8%206-212%20%E4%B8%AD%E5%AF%B9%20DOS%20%E7%9A%84%E6%8F%8F%E8%BF%B0%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%EF%BC%8C%E7%84%B6%E5%90%8E%E5%AE%83%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C%E8%BE%93%E5%87%BA%E5%80%BC%E4%B8%BA%E4%BD%8D%E5%92%8C%E5%AD%97%E8%8A%82%E4%BA%A4%E6%8D%A2%E3%80%82%E4%B9%9F%E5%8F%AF%E4%BB%A5%E4%BB%8E%E4%BD%A0%E7%9A%84%E7%BB%93%E6%9E%9C%E4%B8%AD%E8%A7%A3%E9%87%8A%EF%BC%8C%E4%BE%8B%E5%A6%82%EF%BC%8C%E5%BD%93%E6%9C%AA%E5%90%AF%E7%94%A8%20DOS%20%E6%97%B6%EF%BC%8CCRC%20%E4%B8%BA%200x%20%3CSPAN%3E527d5351%EF%BC%8C%E5%BD%93%E5%90%AF%E7%94%A8%20DOS%20%E6%97%B6%EF%BC%8C%E5%A6%82%E6%9E%9C%E5%AE%83%E5%8F%AA%E5%90%AF%E7%94%A8%E4%BD%8D%E4%BA%A4%E6%8D%A2%EF%BC%8C%E7%BB%93%E6%9E%9C%E5%B0%86%E6%98%AF%200x8acabe4a%EF%BC%8C%E8%80%8C%E5%AE%83%E6%98%AF%E4%BD%8D%E5%92%8C%E5%AD%97%E8%8A%82%E4%BA%A4%E6%8D%A2%EF%BC%8C%E6%89%80%E4%BB%A5%E7%BB%93%E6%9E%9C%E6%98%AF%200x4ab%3C%2FSPAN%3E%20eca8a%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E6%98%AF%E6%9C%89%E9%81%93%E7%90%86%E7%9A%84%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%89%93%E5%BC%80%E4%B8%80%E4%B8%AA%E6%96%B0%E4%B8%BB%E9%A2%98%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2338206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAAM%20endianess%20for%20computed%20CRC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2338206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F124967%22%20target%3D%22_blank%22%3E%40mastupristi%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A3%E5%A6%82%E6%88%91%E4%B9%8B%E5%89%8D%E6%8F%90%E5%88%B0%E7%9A%84%EF%BC%8C%E5%8F%82%E8%80%83%E8%A1%A8%206-212%EF%BC%8C%E5%AF%B9%E4%BA%8E%E8%BE%93%E5%87%BA%EF%BC%8C%E4%BD%8D%E4%BA%A4%E6%8D%A2%E5%92%8C%E5%AD%97%E8%8A%82%E4%BA%A4%E6%8D%A2%E9%80%89%E9%A1%B9%E6%98%AF%E5%90%8C%E6%97%B6%E5%90%AF%E7%94%A8%2F%E7%A6%81%E7%94%A8%E7%9A%84%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%B2%A1%E6%9C%89%E5%8A%9E%E6%B3%95%E5%81%9A%E5%88%B0%E8%BF%99%E4%B8%80%E7%82%B9%EF%BC%8C%E4%BD%86%E4%B8%8D%E8%83%BD%E5%81%9A%E5%88%B0%E5%8F%A6%E4%B8%80%E4%B8%AA%E3%80%82%E5%9B%A0%E6%AD%A4%E4%B8%8D%E5%8F%AF%E8%83%BD%E5%8F%AA%E5%90%AF%E7%94%A8%E4%BD%8D%E4%BA%A4%E6%8D%A2%E8%BE%93%E5%87%BA%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%89%93%E5%BC%80%E4%B8%80%E4%B8%AA%E6%96%B0%E4%B8%BB%E9%A2%98%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
